fuel starving and hesitation
Old Jul 30, 2009 | 12:14 PM
Lethal_Threat's Avatar
Default fuel starving and hesitation
we are working with a 97 civic sedan with a b18b1 with gsr trans. i pretty much am needing to know what engine harness to use without having to change the rest of the wiring. i think what is happening is the harness is so hacked up the ecu doesnt know exactely what to do. so when i start it (cold start) it will idle for about 15mins. then bog down and almost die then it will catch itself and rev. back up, it dies that like 3 times then its fine. then when i drive it, there is a hesitation sometimes at like 3k rpm but mostly around 5k rpm. what do you think?
Old Jul 30, 2009 | 12:20 PM
Former User's Avatar
Default Re: fuel starving and hesitation
Is the ECU matched to the engine and tranny?
Any CEL codes?
Old Jul 30, 2009 | 01:15 PM
yes im running the ls ecu, i havent tried another ecu but it ran fine with that ecu when it came out of the integra. yes i have a couple of codes an o2 sensor code which i have to get one, a code about the fuel trim i think being to lean.
Old Jul 30, 2009 | 01:23 PM
Fixing the O2 sensor code may solve most if not all of the problems.
Old Jul 30, 2009 | 01:35 PM
ya i dont know if that is going to do it because i had an o2 sensor in there before and it did the same thing i took it out after getting it caught up with my axle, it was an o2 sensor that was extended for a header, well i could try that again because i know that has a great deal in fuel trim and every thing i am still using a d series wiring harness out of an ex that shouldnt matter right?
Old Jul 30, 2009 | 01:39 PM
When I said fixing the O2 sensor, I meant doing repairs that eliminate the O2 sensor code. The actual fix seems to be repair of the wires. Also consider that the problem might be a bad ECU.
Old Jul 30, 2009 | 01:53 PM
ya i figured that could be, so i am going to borrow a friends ls ecu to be sure and as far as the o2 sensor it might be a bad sensor to start with so i am gonna get a hold of one that hasn't been tampered with and see what happens do you know off hand if an ls has a charcoal canister that has a sensor on it? my old d series did and i am using that same box and of course the wiring harness
Old Jul 30, 2009 | 09:29 PM
bigweave2's Avatar
I did a b18b1 in my 98. I used the civic harness. Nothing needed to be hacked up. I just had to extend a few wires.
What happened to your harness?
Old Aug 1, 2009 | 08:44 PM
ya i know but i had like 3 different swaps in my car and required different plugs on all of them, finally went dohc though and so far i like it alot just need to get it running in tip top shape
Old Aug 3, 2009 | 06:17 AM
ok so i tried another p75 ecu to see if it would work, made it a little better but not much, it still cuts out really bad its like running a chainsaw on half choke if you know what that is like well minus the smoke lol any other ideas? i am gonna try an o2 sensor later today when i get off work.
Hardedge
Feb 11, 2008 12:32 AM
idontneedvtec
Jun 27, 2004 02:13 PM
go250mph
Jun 5, 2004 09:58 AM
SupaSh0ck
Jan 19, 2003 01:39 PM
