Is the s300 significantly better than the s200 w/boost
Old Jul 30, 2009 | 08:39 AM
eviltwing35's Avatar
Default Is the s300 significantly better than the s200 w/boost
Hey guys, I need a little help. I have the s200 in my 99 em1, over the last year or so I have changed the turbo, DP, and switched from a cast to tubular manifold. Now I need to have the car tuned and I am finding most tuners have switched over to the s300 and dont do the s200 anymore. Joe at tempest built and tuned the car for me originally but now I have moved to Fl and he is in MD so its not cost effective to send the car back to him. This car is my toy and I have put less than 3k on it in the last 3 years. So the question is...Is it worth the investment to switch over to the s300 or should I keep the s200 and find a tuner. Sorry for the long post. BTW my power goals are around 400 whp not sure if this matters though.
99 mr si
b16a stock head
goldzilla sleeves
weisco pistons
eagle rods
tubular mani
Precision Sc44
apexi avcr
Old Jul 30, 2009 | 02:54 PM
Turbogixxer's Avatar
Default Re: Is the s300 significantly better than the s200 w/boost
Best thing about the S300 is that you can run a PWM boost controller. With that, you can have boost by gear/rpm, and be able to ramp the boost. With that alone, I would make the switch to S300.
This is what ramping boost is. This car had a creep problem, so I ramp the boost so it would have the same PSI from about 5200rpm to 9500rpms. You can see the difference.
It is with neptune, but same difference:
Old Jul 31, 2009 | 06:22 AM
Thanks turbogixxer I appreciate the info. I guess I will switch over, After doing the math on keeping the 200 vs the 300 it works out to be almost the same...Now I just have to find a tuner hear in south florida...are you a tuner is see your in boca which is not far from me.
Old Aug 1, 2009 | 07:13 AM
Yeah, I tune around The PBC, broward county area
Old Aug 4, 2009 | 06:23 AM
excellent can you Pm me your info..
Old Aug 5, 2009 | 06:39 AM
PACT man's Avatar
lol@coles dynograph...
turbogixxer(kenny) is a good tuner, i would recommend him for ur turbo tuning needs
jv88_dc2
Jun 12, 2012 03:49 AM
blwn95civic
Apr 5, 2007 09:41 AM
Willie
Jan 15, 2005 10:45 AM
flip1199
Jul 20, 2003 11:19 AM
The Poopsmith
Dec 14, 2002 01:35 PM
