air/fuel gauge help
so i got the gauge hooked up. i tapped into the white wire after the clip so its tapped into the engine harness side. but the lights dont come on until i rev past 4k.. when im idleing nothing is coming up. i would try to tap into the wire on the ecu but i cant find wire diagrams anywhere. i have a p06 computer. is this normal? i thought when you hook it up it should light up all the time while the car is running.
dude.... what are you doing? please elaborate
that white wire is for datalogging i think or is that the blue wire
are you talking about tapping into the o2 sensor to read it?
im tryin to get my a/f gauge to work right. i tapped into the white wire on the o2 sensor but on the harness side.(after the clip) but the a/f gauge only reads when im over 4k rpms. did i tap into the right wire? i was thinkin about tapping into the wire on the ecu to get a better reading. but idk what wire it is..
so your installing a bling gauge? Sounds like a narrowband gauge judging by the OP.
If you want somthing that'll actually work and be accurate look into AEM or Inovate afr gauges
wutiteez
Dec 1, 2006 06:06 PM
boostng r
Sep 18, 2004 10:57 AM
wickedxboi
Mar 10, 2003 05:37 PM
