6x9 only producing nothing but bass, need to know adjustments.
Old Jul 29, 2009 | 02:31 PM
SpadedEK's Avatar
Default 6x9 only producing nothing but bass, need to know adjustments.
hey whats up guys,
I just installed a set of 6x9s in my ek hatchback (did not come with rear speakers) so instead of cutting my passenger side wiring harness looking for the stock wires, i hooked up my apm and ran the wires to the speakers directly. the thing is now they are only producing bass, when i turn the sub mode off on my headunit they make no noise whatsover. i need to know how to get them producing bass mid and hi's. i will list the adjustments that are avaible to me.
- crossover point dial
- lpf , apf, hpf,
- subwoofer mode on pioneer headunit
- or do you guys think i may have crossed the connections wrong like negative to positive
like i said nothing but bass comes out of them right now...
Old Jul 29, 2009 | 03:13 PM
audioroach's Avatar
Default Re: 6x9 only producing nothing but bass, need to know adjustments.
switch the xover to all pass
Old Jul 29, 2009 | 03:30 PM
SpadedEK's Avatar
i will do that and then where should i go from there
Old Jul 29, 2009 | 06:37 PM
Skip01's Avatar
Is the bass going along with the music?
What kinda amp going to 6x9s?
Turn lpf on the highest setting, maybe 120ish i think on my old Pioneer, should cut out 120hz and lower....or go higher if you have it
Old Jul 31, 2009 | 08:20 AM
SpadedEK's Avatar
Ok swithched to apf. Now when I have subwoofer off on my head unit the speakers only make white noise and static. When I turn subwoofer mode on all I here is horribly distorted bass that goes with the song. Its a rockford fosgate 2 channel amp
Old Jul 31, 2009 | 09:07 AM
ffswizzlestick's Avatar
Does your radio only have one set of pre-outs? If there are ones for the speakers, hook your rcas up to that. Also check the x-over on the radio. I think a lot of Pioneers come set at 80 Hz LPF default. See if you can turn that x-over off. Otherwise you might have to wire to the speaker outputs of the radio and run speaker wire back instead of the amp.
Old Jul 31, 2009 | 09:50 AM
twentyhurtz's Avatar
yep get off the rca sub ch, thats probably gonna clear up your problem, if you do not have another set of rca's, get a loc.
Old Jul 31, 2009 | 11:58 AM
I think an LOC would probably be a waste. An amp is not needed for those speakers, I would guess, and he could run off the H/U power. If he's already tapping into speaker wires, he might as well do it with just more speaker wire and run it straight to the 6X9s.
Old Aug 1, 2009 | 12:37 PM
fcm's Avatar
fcm
Old Fart
If the HU has a set of sub-woofer outputs it is a good bet there is a set of front, rear or both, full range outputs.
Amp setting must be apf or hpf and a full-range signal must be used from the HU the HUs sub-woofer output should not be used.
What is the model of the Pioneer HU? 94
Old Aug 1, 2009 | 02:04 PM
SpadedEK's Avatar
problem solved i had to sets of outputs. one for the sub and another for speakers thanks for all the help
Lou_EM1
Audio / Security / Video
May 31, 2016 02:33 PM
nenetech
Aug 17, 2010 10:30 AM
Liquidgsr
Jul 16, 2008 09:04 AM
Jxi8s2k
12
Dec 22, 2006 11:38 AM
jokerstud
Jun 22, 2003 04:24 PM
