need help wiring knock sensor
Old Jul 29, 2009 | 01:22 PM
beginmyhonda's Avatar
Default need help wiring knock sensor
hey i got a obd2-obd1 gsr swap in my civic using p72 obd1
i dont know how to wire knock sensor but i know where its located.
i have look at forums about how to wire to plug for ecu which i did that
i was wondering how they wire that to the knock sensor and which color are the wire(s) and how many wire(s) are there.
i basically got a 3-4ft wire and wire inside to firewall to plug for ecu on D3 but i dont know how to wire the wire to the knock sensor itself.
if anybody can help me that be great
correct me if im wrong about anything
Old Jul 29, 2009 | 01:25 PM
redlinetuning's Avatar
Default Re: need help wiring knock sensor
you'll need a knock sensor plug with pig tails, that's the easiest. What civic do you have? I believe it's a two-prong plug.
Old Jul 29, 2009 | 01:27 PM
vtechjunkie's Avatar
If I remember right, there is a clip thingy that goes on the sensor. It doesn't get directly wire to the sensor. I have always had them omitted from my set-up.
Old Jul 29, 2009 | 01:28 PM
Damn redline! You and I were responding at the same time. What he said op.
Old Jul 29, 2009 | 02:14 PM
im got a 94cx using obd2 engine harness
yes there is a two prong plug that goes in the knock sensor though
TO VTECJUNKIE: so i have to cut that open and fine that wire and connected it to my existing wire from the ecu plug?
eskerley
Dec 4, 2007 08:18 PM
phanatic
May 18, 2007 02:21 PM
Dragline
Aug 19, 2005 12:45 PM
99hatch
14
Jan 9, 2005 05:30 PM
