couple of turbo questions
Old Aug 23, 2002 | 07:38 PM
_Endless_'s Avatar
Default couple of turbo questions
on a stock b16a, theres 2 things connected to the intake tract, a hose that is connected to the valve cover and a sensor with 2 wires.
when boosting the b16a, where should i connect the hose from the valve cover? i heard that it's not good to just put a breather filter.
what do you call that sensor connected to the intake tract of a stock b16a? where do you guys put it once you boost your b16a?
i already have a vortech rising rate fmu, is that enough for my fuel concerns without changing to a high flow pump and fuel regulator?
[Modified by _Endless_, 4:49 AM 8/24/2002]
Old Aug 23, 2002 | 08:03 PM
ekb18c's Avatar
Default Re: couple of turbo questions (_Endless_)
You should always get a 255lph pump for boost. If your going to boost ~7 psi then yes, you should get an inline or intank 255lph feul pump.
CzanSOHC's Avatar
The sensor is an IAT sensor, most people put it right after the airfilter, along w/ the hose to the valve cover..
You will need a larger INLINE fuel pump w/ that FMU...
Old Aug 23, 2002 | 08:29 PM
_Endless_'s Avatar
Default Re: couple of turbo questions (CzanSOHC)
thanks. so that thing is an IAT, but where do i put it when turbocharging? you said to put it right after the airfilter, so do you mean it should be put in between the filter and compressor inlet? coz in stock form, it's after the filter.
Old Aug 23, 2002 | 08:39 PM
ion_four's Avatar
Default Re: couple of turbo questions (ekb18c)
No. You should always get a better pump if you're using an FMU. If you were using larger injectors and a MAP sensor scaling circuit (or VAFC) you would be fine with the stock pump (as am I).
Old Aug 23, 2002 | 11:28 PM
_Endless_'s Avatar
Default Re: couple of turbo questions (ion_four)
how about the IAT sensor where do you put it when turbocharging?
spoon95eg
Feb 7, 2006 04:14 PM
psyphre
Nov 1, 2005 01:26 PM
crucial si
Apr 22, 2003 12:17 PM
juicy.koreans.suck
Jul 14, 2002 08:36 PM
Giuseppe
Sep 24, 2001 10:36 PM
