sohc turbo questions...
im about to install my kit
anyhow..fuel questions...
will the fmu supply enough fuel or will i need an inline pump?
this is on 5.5lbs of boost...
what will i need later on to boost more safely?
Re: sohc turbo questions... (crucial si)
FMU + stock fuel pump = new motor.
You might get away with it for a little while, but it'll catch up to you sooner or later when your pump quits while trying to flow fuel at 100psi of rail pressure.
Re: sohc turbo questions... (VTC_CiViC)
So should you put an inline pump in or should you put a bigger pump in your tank. I heard that at low PSI (like 6) you need an FMU, but the stock internals and fuel would handel the load.
red civic standard
10-10-2002 07:47 AM
