my vtec is not working need help
Old Jul 27, 2009 | 07:31 PM
phaphon's Avatar
Default my vtec is not working need help
wassup i have a 89 civic sedan i had a lsv that i spun a rod bearing and ever since that i swap a b20 in and now my vtec is not working everything is wired correctly im pretty sure cause it was working everything is wired to the ecu i check my cel and it throws code 10 and 14, 10 being the idle air temp. 14 being the eacv..i have oil in my car with a vtec ecu thanks if anyone can help obd0 pr3 virgin ecu
Old Jul 27, 2009 | 08:34 PM
BiGZ's Avatar
Default Re: my vtec is not working need help
Not enuff info given-what ecu mang? OBD0 chipped,OBD1 or?
Old Jul 27, 2009 | 08:36 PM
phaphon's Avatar
sorry but yeah its a obd0 pr3 ecu stock
Old Jul 27, 2009 | 09:09 PM
EF9Si-T's Avatar
Is your Intake Air Temp sensor connected? Check your wiring and also fix the eacv problem as well, then figuring out why VTEC is not engaging will be alot easier.
Old Jul 28, 2009 | 04:36 PM
papo09's Avatar
is ur speedomiter workin. if not ur vtec wont work. i had that problem
Old Jul 28, 2009 | 04:52 PM
LightWeightED8's Avatar
You can apply battery voltage to the solenoid, if you hear it click that will eliminate that as a problem...But as other said, need more info.
Is it off all the time or is intermittent? Is your water temp over 60 degrees celsius???
Old Jul 28, 2009 | 07:06 PM
ef-hatchcrap's Avatar
Just switch the 2 plugs around reset the battery
Old Jul 28, 2009 | 07:58 PM
phaphon's Avatar
I've applied voltage to the solenoid and i hear it click, i believe my iat is not connected can someone correct me please that is the sensor on the manifold near the fuel rail right ? and yes my speedomitor works.hrmm i will try to fix the cels the eacv light has always been on never been able to fix it i think it has to do with a wiring problem
Old Jul 31, 2009 | 06:50 PM
phaphon's Avatar
bump TTT vtec still not working
Blake450
Jul 29, 2013 11:50 AM
firstb16swap
Oct 10, 2011 09:18 PM
dougk1401
Dec 7, 2009 08:55 AM
vtieg6
Nov 7, 2009 08:16 PM
type Gendy
20
Mar 10, 2005 07:00 PM
