Impossible idle problem
Old Jul 27, 2009 | 03:23 PM
snake_eyes's Avatar
Icon2 Impossible idle problem
Ok ive checked everything related to my erratic idle it goes up and down nonstop. The iacv is good, the map sensor is good,no vaccum leaks, tps is good, i totally cleaned my throttle body. No cel, im out of ideas. Its a 92 4door civic auto trans d15b non vtec, any one have any ideas? Please help! Thanks
Old Jul 27, 2009 | 03:28 PM
shawn_crx's Avatar
Default Re: Impossible idle problem
engine code?
Old Jul 27, 2009 | 04:28 PM
Former User's Avatar
Does the hunting idle stop if you cover the port leading to either the IACV or FITV with your finger? Have you tried bleeding the cooling system? Can you kill the idling engine by covering the top of the throttle body with your hand?
Old Jul 27, 2009 | 05:15 PM
reyracerx's Avatar
is it too low of an idle or too high of an idle?
if its too low of an idle being that you have an auto trans it can be that your trans is going out.
Old Jul 27, 2009 | 06:03 PM
VegasInvasion's Avatar
I'm Huge In Japan
https://honda-tech.com/forums/showth...light=end+idle
-- Also, if you've recently done work involving draining the coolant system, you likely have bubbles in the FITV/IACV coolant lines. Refer to your manual for bleeding instructions.
Old Jul 28, 2009 | 04:59 AM
90Rexx's Avatar
remove fitv, take the cap off, and screw the white plastic peice all the way down.
^^ do that then let us know how it worked
Old Aug 26, 2009 | 10:43 AM
snake_eyes's Avatar
the white thing in the fast idle valve under the throttle body was loose. i screwed it in and it runs fine now thanks guys
Old Aug 26, 2009 | 10:59 AM
90Rexx's Avatar
haha good guess on my part... everyone seems to skip that step in the "guessing game" of fixing idle issues lol
Old Aug 31, 2009 | 12:24 AM
snake_eyes's Avatar
yea i had a customer tell me to check that out
thewrai6th
Oct 28, 2018 05:32 PM
ILoveJDM.
Dec 25, 2005 11:34 AM
mafay2
Jul 13, 2005 11:52 AM
CRX-SIR
Sep 20, 2004 06:00 PM
Vp Special K
Apr 4, 2003 09:14 PM
