civic swap h22a not running!!
Old Jul 27, 2009 | 02:09 PM
kct01's Avatar
Default civic swap h22a not running!!
I have a h22a in a eg and today I was driving it to work and the check engine light came on. I thought nothing of it and it shut off when I turn the car off. After about 30 mins I went to drive it the check light was still off but the car started to bog in the lower rpm. I drove it home and it parked it with the car on. I press the gas and it started to bog and then it died on me. After it died white smoke came out of the intake filter. I tried to start it up but it won't start and when it does it bogs and dies again. The only thing that I have done to it before was I engine degreased it and watered it down with the hose but after I hosed it down I let it dry for a bit and took it out for a spin and it was okay and I also sprayed that k&n filter kit on it with the cleaning solution and oil recharger kit. Someone help me plz.
Old Jul 27, 2009 | 02:23 PM
AccordNation's Avatar
Default Re: civic swap h22a not running!!
i was wondering how did you do your wiring in the car from the motor
Old Jul 27, 2009 | 03:19 PM
kct01's Avatar
Not to sure about the wiring cuz someone did that for me but back to the car problem, the car starts now but when I gas it WOT it bogs and chokes. When I slighty gas it, it revs up fine.
Old Jul 27, 2009 | 03:57 PM
JonMaltese/LScivic's Avatar
well u obviously got something wet( how do u know there arent any exposed wires in the harness since u didnt swap it??) or u just got some of the ignition system wet like( dizzy,wires) .. the engine light was probably a misfire code
Old Jul 27, 2009 | 04:59 PM
g230sport's Avatar
pop the distributor cap off. i have a feeling its wet inside...
2000civicH22A
Oct 30, 2015 03:18 PM
lilrak72
May 2, 2012 08:24 PM
Shadowz7429
Jul 4, 2007 04:54 PM
Freddiesluda
Mar 3, 2005 01:03 AM
greebler
Oct 4, 2003 11:41 AM
