Del Sol Swap
Old Jul 27, 2009 | 11:07 AM
M_W A_R_M_Y's Avatar
Default Del Sol Swap
I have the d15 stock motor in my car right now and i want to get the vtech d16 motor but im not sure on what i need to do this. Please help
Old Jul 28, 2009 | 10:42 PM
Default Re: Del Sol Swap
TTT
Old Jul 29, 2009 | 04:43 AM
mhopkins10's Avatar
you need a complete swap i would go with a bigger engine like the b16 or b18. The motors set right in the same place you will need a wiring harness, motor mounts, transmission, and ecu if you buy a complete swap you will get everything you need expect for the motor mounts which you can get at autozone or such. But if you want to just swap engines same series motor you can use everything form the d15 you just need the man hours to do. Hopes help if not let me know what more specific you are wanting to know
93 Del Sol Si D16Z6
Old Aug 2, 2009 | 07:01 PM
Well i was thinking about a sohc turbo would be cheaper then doing a b series swap. To make sure its clear if i were to get the d16 in all i need is a motor and everything from the d15 will work for it.
Old Aug 2, 2009 | 07:33 PM
mhopkins10's Avatar
Yeah everything will work you will be good to go so all you will need is the motor and turbo
SinnCityVic
K Series
Jan 9, 2015 12:26 PM
Draiga1988
May 16, 2011 03:57 PM
HankTrigg
Aug 3, 2008 09:57 AM
CoolJimWhy
16
Oct 19, 2004 06:58 AM
