Initial timing set-up tdc distributor position?
Old Jul 26, 2009 | 10:06 PM
stellium's Avatar
Default Initial timing set-up tdc distributor position?
Ok,
1993 honda accord ex-r changing broken motor for a recycled one...
Got the motor out, gonna take the accessories off the current motor and prepare the new powerplant for installation. I am rtaking the distributor off the current motor and installing it on the new motor.
So as not to be too far off at initial start-up, does anyone have any tips or trick to setting timing advance? Mainly so it fires when I finish hooking everything up...
Thanks is advance...
Jacques
Old Jul 26, 2009 | 10:23 PM
whitewonder's Avatar
Default Re: Initial timing set-up tdc distributor position?
the dizzy only fits one way. its off center to one side.
If tension and all timing marks are correct it should start right up ...
is this what u are asking ?
Old Jul 27, 2009 | 01:15 AM
cctgene's Avatar
What I would do is put the the number one cylinder at top dead center and then make sure your rotor is pointing toward the number one spark plug wire, on the distributor, before you install it.
MastaFlyMason
Oct 2, 2016 02:53 PM
tobster
Engine Management and Tuning
Aug 20, 2010 05:55 AM
azzurribaggio
Jun 26, 2009 09:25 PM
azzurribaggio
Jun 26, 2009 05:07 PM
_Endless_
Apr 29, 2003 10:17 PM
