Suspension & Brakes Theory, alignment, spring rates....
Dumb(?) question, camber kit spec meanings
Old Jul 26, 2009 | 09:59 PM
jmai86's Avatar
Default Dumb(?) question, camber kit spec meanings
Lookin for more negative camber.
If an aftermarket upper arm / camber arm kit/ camber balljoint kit is spec'ed at -3 to +4 correction, does it mean -3 MORE camber than the natural camber on a lowered car? Or -3 total?
So if I have -2 camber now, with the kit could I achieve -5 degrees?
Old Jul 27, 2009 | 06:47 AM
alphalanos's Avatar
Default Re: Dumb(?) question, camber kit spec meanings
total. Why do you need more camber? If its a street car you should keep the stock upper A arms, the ball joint is flush so it doesnt reduce travel. And probably a better quality ball joint too.
Old Jul 27, 2009 | 01:23 PM
jmai86's Avatar
It's purely for cosmetic reasons; I'm fitting some aggressively sized (width & low offsets) wheels.
Guess I'll have to look elsewhere, thanks.
Old Jul 27, 2009 | 01:27 PM
TunerN00b's Avatar
Yes, most kits listed with a range, mean it can adjust that much from whatever you have now.
I'm running a +-3* sliding balljoint SPC UCA. Current alignment is -4* of front camber, -2* (give or take) from lowering, and the rest from the kit.
Old Jul 27, 2009 | 03:31 PM
jmai86's Avatar
Alright so now I have two different answers, or I'm just confused again lol.
So you're saying that if I have, say -2 natural camber now with stock arms from lowering, a camber kit rated at +-2 deg. would give me a -4 to 0 deg. range right?
Old Jul 27, 2009 | 04:54 PM
TunerN00b's Avatar
It should do that, yes.
Some of them that I have seen don't quite offer the full range advertised, but if it is listed as a +- range, it should allow more negative camber than lowering alone provided.
Old Jul 27, 2009 | 04:58 PM
jmai86's Avatar
Awesome, thanks. I'm gonna go for it.
Dirty Octopus
28
Feb 20, 2010 05:47 AM
BJA86
11
Sep 2, 2007 01:00 PM
PearlH22
Sep 10, 2006 04:47 PM
KiNG $h!t
Suspension & Brakes
Mar 7, 2005 10:52 AM
tr4il
Nov 23, 2001 10:14 AM
