Some CEL codes..
Old Jul 26, 2009 | 06:23 PM
Choy's Avatar
Default Some CEL codes..
so i got some CEL codes pulled off my 99 civic si
1.BBA/F sensor 1 heater system malfunction
2.BBsecondary H02s12 circuit heater circuit malfunction
3. BBElectric load detector(ELD) circuithigh input
the guy at the store said my ECU may be bad but i dont know.
what do all these mean and how can i test my ECU to tell if its bad?
Which should i start with to see if they take the other problem away?
Old Jul 26, 2009 | 07:44 PM
Choy's Avatar
Default Re: Some CEL codes..
¢¢∞¢§¶•ªº¡™£¢∞§§¶•ª bump˙∆˚¬…≤µ˜∫↑
Old Jul 26, 2009 | 08:18 PM
Former User's Avatar
If fuse 15 under the dash is blown, click here.
Old Jul 27, 2009 | 09:06 AM
Choy's Avatar
fuse 15 is fine
Old Jul 27, 2009 | 11:55 AM
Choy's Avatar
Old Jul 27, 2009 | 01:25 PM
Does the speedometer work?
Old Jul 27, 2009 | 01:26 PM
Choy's Avatar
yes
Old Jul 27, 2009 | 01:33 PM
If you clear the ECU by removing the BACKUP fuse under the hood for a couple of minutes and then drive the car, do all three codes repeat?
Old Jul 27, 2009 | 01:38 PM
Choy's Avatar
im not sure il try to test that out and see. which fuse is it?
Old Jul 27, 2009 | 01:40 PM
The fuse labeled Backup under the hood.
Old Jul 27, 2009 | 02:16 PM
Choy's Avatar
all i see is this one. says backup(radio)
Old Jul 27, 2009 | 02:20 PM
That's the one.
FYI -- You'll need to reset your clock and radio stations after clearing the ECU.
Old Jul 27, 2009 | 02:30 PM
Choy's Avatar
lol its cool i have to get that setup as well. so il do that then il get back to u.
Old Jul 27, 2009 | 02:37 PM
Choy's Avatar
any recommended amount of minutes to wait and minutes to drive? what code should this be testing out?
Old Jul 27, 2009 | 02:43 PM
Removing the fuse for 2 minutes should be enough to clear the ECU codes. Afterward, drive the car for 15 minutes or so to see whether the CEL stays on while driving. If so, pull the CEL codes again yourself as described here. You are trying to determine whether any of the codes you posted earlier repeat. You should only troubleshoot codes that repeat. If the CEL does not stay on after clearing the codes and driving, then you may be good to go.
Old Jul 27, 2009 | 02:49 PM
Choy's Avatar
alllllrighty
Old Jul 27, 2009 | 03:29 PM
Choy's Avatar
alright. all the CELs went away but the o2 sensor cell. i guess il just have to replace those. thanks alot man.
Old Jul 27, 2009 | 04:25 PM
Does one or both O2 sensor codes remain? Which one?
Old Jul 27, 2009 | 06:18 PM
Choy's Avatar
i believe it was this one BBsecondary H02s12 circuit heater circuit malfunction
Old Jul 27, 2009 | 06:25 PM
That's the secondary O2 sensor plugged into the rear, top of the cat. Check the wires for damage before you replace. I hope that P0420 doesn't pop up after the you fix the secondary sensor because this could mean that the cat is bad.
Old Jul 27, 2009 | 06:45 PM
Choy's Avatar
me to. how much does a cat go for?
Old Jul 27, 2009 | 06:48 PM
Suffice it to say that you don't want to throw a cat code.
Keizer
43
Jul 29, 2013 01:16 PM
greeen ranger
Jun 16, 2013 06:38 PM
pang_yeng
21
Nov 24, 2011 05:52 AM
Mr.Death
Jun 10, 2007 08:44 AM
dj626
Sep 27, 2004 03:31 PM
