is any one put down over 450 whp on a stock BLOCK GSR?
I am wondering if anyone has put down over 450 whp on a stock sleeve block with out a block guard(on PUMP GAS) . My goal is 500 but i am almost sure i will have to be running atleast a sleeved block but just wanted to see if any one has. Post your numbers if you dont mind. I have a STOCK GSR with a SC61 that put 378whp
i would check this thread out a lot of people have put down big numbers on stock block.
https://honda-tech.com/forums/showth...st+stock+block
^^ yea he did 494 on e85 heres the thread. https://honda-tech.com/forums/forced-induction-16/bone-stock-gsr-turbo-494whp-e85-2606630/
i just made 450 on 19psi. stock motor. eagle rods. nippon cast pistons. and arp head studs. that's it. and it was a really hot day at that..
We did a 495 whp stock gsr. The last dyno pull pushed some water into the overflow. Turned it down a little and ran it. Went 11.0 in an EJ1. Ran like that for a few months with no problems.
How are ealge rods a stock motor?
Ive seen a 515whp stock ls/vtec with ITR cams. And a 532whp bone stock GSR with ARP head studs. All on E-85, but it is possible with the right tune
yeah im just wondering because i plan on building a dart block soon but with the turbo set up i have on a bone stock internal GSR(only has skunk2 im) put down 378whp but i am moving to an area that sells e85. But it is at 6000+ ft elevation. I dont have any idea how big of a change it will make. anyone know a GOOD AEM EMS tuner in colorado springs
