idle rising then dropping over and over.
the car: rsx base 5 speed
the problem: after about a 45 min drive. i come to a stop and notice my my rpm's are around 1500. it stays there and drops to idle and then rises up again and drops to idle. it does this for about 10 or 15 minutes when ever i come to a stop, and then for the rest of the drive is normal(5 or 10 min). i took it easier than normal but it drove fine otherwise.
what could be the problem?
can also be a vacuum leak
do you by any chance have a light weight flywheel??? They often cause fluctuating idle because the flywheel mass is too light for it to idle well at low RPM's (which is why most people with Kpro bump their idle up a bit)
Basically, it could be a number of things. So start with the cheapest checks and go from there. You're bound to figure out what it is eventually.
Remove the intake while its bouncing and plug the port to the IACV with your finger. If it stops bouncing, its something with the IACV. My K20 swap was doing the same thing a few weeks ago. Pulling the IACV apart and cleaning it solved the issue for me.
If that does not do anything, keep going down the list.
