Wheels keep spinning?!
From: You may think I can't see you..but in reality..I could see you very clearly..
I was replacing my throw out bearing in my transmission well after putting it all back together i try to start the car and the clutch pedal falls to the floor. I then think well maybe i should bleed the breaks so i bleed them from the slave master cylinder and they stiffen up some. Later i start the car and for some reason the wheels keep spinning even in neutral, car is up in the air some so i could clearly see something was wrong..i pressed in the clutch and saw no movement in the slave master, i loosen the bleed screw and step in the clutch and the slave cylinder engages and the wheels stop spinning. Once you let go they continue. I appreciate all comments info and advice thanks!
If the wheels are spinning in the air while in neutral, its normal since I've seen it all the time on my car when I'm done with my swaps. But once you lower it to the ground, its not doing anything at all, so its normal.
I think you just need to have somebody pump the clutch pedal while you loosen up the bleed screw till it pressures up and it might take a while too.
TedR719
Dec 18, 2007 12:20 AM
Lei Siew Long
Oct 22, 2002 10:43 AM
