Transmission & Drivetrain Gearboxes, Differentials, Clutches
Tranny slide/grind.... :(
Old Jul 25, 2009 | 04:58 PM
velisma's Avatar
Default Tranny slide/grind.... :(
Ok, so I bought a 94 gsr tranny, installed it on my b16a and got the infamous sliding/grinding noise. I have researched quite a bit have found quite a bit of different answers on the subject. First, a little background... I bought a 12lbs flywheel, pilot bearing and xtd replacement clutch for my car. The car has been sitting w/ the above items installed in it in my front driveway for probably the better part of a month or a little longer. These are the symptoms I noticed when taking it for a test drive.
1) with the car parked and clutch depressed the tranny is dead quiet.
2) when in neutral and foot is off the clutch there is a grinding/sliding noise
3) when the car is moving and I am coasting w/ the clutch depressed or foot off of it, there is a grinding/sliding noise
So.....
Pilot bearing?
ISB?
Something else maybe?
Old Jul 25, 2009 | 07:21 PM
velisma's Avatar
Default Re: Tranny slide/grind.... :(
bump 4 an answer
Old Jul 26, 2009 | 09:21 AM
velisma's Avatar
bump
Old Jul 26, 2009 | 09:25 AM
Garage 808 Hatch's Avatar
sounds like either a throw out bearing, or bad input shaft bearing to me
Old Jul 27, 2009 | 07:45 AM
velisma's Avatar
Well, took the tranny out yesterday and pulled it apart to see what I could see. It was a fried input shaft bearing. I could tell immediately when I opened the case cuz there was ISB particles all over the magnet inside. Replaced it, and now she is quiet as can be again.
Sic_DA_Nine
Mar 23, 2007 06:02 AM
SJR
Apr 25, 2005 06:16 AM
JDM SLICK
Feb 15, 2005 11:17 PM
Bbasso
Sep 14, 2003 11:17 PM
BoostedsiR
May 31, 2003 05:28 PM
