Ek ex disc brake?
Old Jul 25, 2009 | 12:54 PM
Ghettopoptart's Avatar
Default Ek ex disc brake?
Question, i have a friend with a wrecked EK, ex coupe, will his disc brakes fit on my 92 CX hatch? if so what all do i need to take off of his?
Old Jul 25, 2009 | 01:37 PM
EL Vap133's Avatar
Default Re: Ek ex disc brake?
Yes they will, you will need tools like the following:
1. Jack
2. Jack Stands
3. Ratchet
4. Sockets (17mm, 14mm, etc)
5. 10mm Flare Nut Wrench
6. Needle Nose pliers
7. Tire iron
8. Something to catch leaking brake fluid
9. WD-40 to loosen up rusted bolts
10. Elbow grease
11. If there is anything else I missed someone please fill in the blank.
Old Jul 25, 2009 | 03:21 PM
I ment, what do i need to take off of his car, as in, obviously the hub, but what else, or is that the only thing
Old Jul 25, 2009 | 03:58 PM
Unseen Racer's Avatar
1. Jack
2. Jack Stands
3. Ratchet
7. Tire iron
10. Elbow grease
thats about it.
oh and patience!(spelling??)
well if its wrecked just remove everything that is connected to the disk brakes.
so axle nut, axle, lower control arm, trailing arm, etc.
Old Jul 25, 2009 | 04:00 PM
its the rear disc, i have front disc
Old Jul 25, 2009 | 04:02 PM
thi3v3z's Avatar
i didnt know 96-00 ex came with rear discs... unless its a conversion
Old Jul 25, 2009 | 10:40 PM
it doesnt.
and yes it is converted.
Old Jul 26, 2009 | 03:58 AM
slugo10's Avatar
Take the whole lower control arm and the e-brake cable.
Old Jul 26, 2009 | 04:41 PM
oh and i forgot to tell you that if EVERYTHING was swapped out correctly, take the 40/40 prop valve as well as the brake master cylinder.
you do not really need the brake master cylinder but its a good thing just to swap it out
heunde
Jun 12, 2009 02:13 PM
Bone Stock
Dec 4, 2005 02:19 PM
93civicsedan
Sep 26, 2005 09:21 PM
97civicsedan
Jul 6, 2005 07:46 PM
mrcch
Jun 9, 2004 12:39 PM
