How to run lines ? .. Aeromotive FPR + stock fuel rail
Old Jul 25, 2009 | 07:49 AM
street_ride14's Avatar
Default How to run lines ? .. Aeromotive FPR + stock fuel rail
H22 motor, utilizing stock H22 fuel rail ..
I've got this inline FPR by Aeromotive with ( 2 ) -6an fuel inlet ports and -6an fuel return port. So my 2 questions are where does this FPR go ? (ex.. between fuel filter and fuel rail .., ect. ) and what do I do with my factory FPR and its fuel rail port ?
pics would help greatly, thanks.
Old Jul 26, 2009 | 10:50 AM
Default Re: How to run lines ? .. Aeromotive FPR + stock fuel rail
anyone ?
OR help me.. trace a drop of fuel from the time it exits the fuel tank to the time in comes back to the fuel tank, fuel drop must go through all OEM lines and components without shortcuts, , You may delete the injectors from your routing as in my example no fuel drop should go through the injector.
Old Jul 26, 2009 | 12:31 PM
92hondalude's Avatar
between the filter and rail. your going to need some new lines and fitting. i think spooling performance has a little kit made up.
Old Jul 26, 2009 | 01:31 PM
Aeromotive says that it must go "after the fuel-rail" .. http://www.aeromotiveinc.com/faq.php?id=62
Who can tell me for sure ? .. Who has this setup on their 'ludes ?
Old Jul 26, 2009 | 02:10 PM
Rosko's Avatar
If aeromotive says after then thats what you should do. I have that same regulator from the sounds of it.
Fuel Pump>Filter>Fuel Rail>Regulator>Tank
You arent going to be able to use it with a stock fuel rail however since you dont have and outlet besides the regulator port.
ghostriderinnc
Jul 31, 2010 09:38 AM
beginmyhonda
Dec 4, 2009 02:21 PM
EK FLY
Jan 6, 2006 05:04 PM
Slowdriver
May 28, 2004 05:41 AM
paulzy
Nov 25, 2001 07:02 PM
