Transmission & Drivetrain Gearboxes, Differentials, Clutches
What parts to replace when difficult to put in reverse? (links inside)
Old Jul 24, 2009 | 05:33 PM
vtecn8ive's Avatar
Default What parts to replace when difficult to put in reverse? (links inside)
I have a Crx HF that on slight occasion will be difficult to put in reverse and first. It does it whenever it wants, not a huge headache.
I am pulling it out to replace the input bearing and figure I could address that situation too.
I'm unsure what parts to replace (please just parts and tips, none of the 'don't do it' blah blah blah)
http://www.hondaautomotiveparts.com/...+++++MAINSHAFT
^^ in that link its stating a reverse gear. I am aware reverse and 1st are the same gear, so I'm wondering if I need to replace that gear, or do I need to replace a synchro of some sort?
Thanks,
Shane
Old Jul 24, 2009 | 08:25 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: What parts to replace when difficult to put in reverse? (links inside)
1st and reverse are different gears.
Inspect you 1-2 shifter fork and the fricition dampers for first and second gears on the countershaft.
Old Jul 25, 2009 | 11:02 AM
vtecn8ive's Avatar
Wow, I guess I had misconecption this entire time, thanks for clearing that up. First time digging in a transmission. The parts you listed to inspect that would be for reverse too, right? Thanks.
On a side note, Mista Bone are you the same person on Hondacivicwagon.com? I think I see your name pop up occasionally and people commenting (good) about you.
tmramsburg
Apr 30, 2010 02:32 PM
13173
Mar 17, 2010 06:14 PM
aasaa666
Apr 26, 2009 09:09 PM
honda011
May 21, 2005 07:02 PM
