BRAKE BOOSTER HELP!!
Old Jul 24, 2009 | 05:19 PM
PEK*EGGEM's Avatar
Default BRAKE BOOSTER HELP!!
IM TRYING TO UPGRADE MY BRAKE SYSTEM.. WOULD A 91 DA TEG BOOSTER WORK ON A 93 CIVIC HATCH?? THANKS..
Old Jul 24, 2009 | 05:28 PM
shawn_crx's Avatar
Default Re: BRAKE BOOSTER HELP!!
not sure, i think the bolt patterns are difference... but try 94 teg and civic ex's, si's
Old Jul 24, 2009 | 05:31 PM
PEK*EGGEM's Avatar
WOULD 95LS PROPORTIONING VALVE MAKE A DIFFERENCE??
Old Jul 24, 2009 | 05:32 PM
shawn_crx's Avatar
if you not going to upgrade your brake system.. then keep it stock
Old Jul 24, 2009 | 05:35 PM
thumper64's Avatar
Yes, it will work perfectly, at least with the matching master cylinder. The DA brake booster is the same part number as the 94-01 RS (non ABS).
It might be hard to put in the master cylinder and booster together, so put the booster in first, then the master cylinder. Removing the two from a DA when they're bolted together is impossible without removing the intake, at least with an LS engine. And it's a lot easier with an extra hand to hold the booster up while you put the nuts on from behind the firewall.
Old Jul 24, 2009 | 05:41 PM
PEK*EGGEM's Avatar
WOULD THERE BE A DIFFERENCE BETWEEN LS AND RS BOOSTER??
cripemaster
Jun 15, 2010 08:28 PM
RedDelSol si
Mar 10, 2004 07:54 AM
Eggman
Oct 7, 2002 09:18 AM
JeffS
Mar 7, 2002 08:22 AM
