BRAKE BOOSTER HELP!!
Re: BRAKE BOOSTER HELP!!
Yes, it will work perfectly, at least with the matching master cylinder. The DA brake booster is the same part number as the 94-01 RS (non ABS).
It might be hard to put in the master cylinder and booster together, so put the booster in first, then the master cylinder. Removing the two from a DA when they're bolted together is impossible without removing the intake, at least with an LS engine. And it's a lot easier with an extra hand to hold the booster up while you put the nuts on from behind the firewall.
