? For those that have installed cams
Old Jul 24, 2009 | 11:41 AM
sirsol66's Avatar
Default ? For those that have installed cams
Simple question for you guys: Did you use any anything like anti seize or thread locker (i.e. loctite) on the cam holder bolts? When I removed mine (a3 head, 12K miles, untouched), there was evidence of the factory putting something on them based on the grey residue that I saw. The factory manual makes no reference to putting anything on these when rebuilding the head. So, what I want to know:
1) When you swapped cams/built head or whatever that required removing the cam holder bolts, did you just torque the bolts and leave them alone or did you use anything on the threads? I'm not too worried about anti seize but I would worry if honda had put thread locker on it. Any thoughts are appreciated.
Old Jul 24, 2009 | 12:13 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: ? For those that have installed cams
I've never used loctite or any thread locker for cam caps
Old Jul 24, 2009 | 08:21 PM
sirsol66's Avatar
Thanks for letting me know. I'd just like to figure out what the general consensus on this is. Also, I'd like to know if anyone has RELIABLE information as to what it was that the factory put on the bolts, whether it was anti seize (doubtful) or thread locker.
Old Jul 24, 2009 | 08:27 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Every time I take apart a Honda engine I smell the same smell after unbolting cam bolts, crank bolts, connecting rod and etc... I know they have to use something from the factory but another mechanic buddy says it's just from the oil...
Old Jul 25, 2009 | 06:54 AM
sirsol66's Avatar
Well, this bolt literally had residue of something on the threads, I'm sure it wasn't just oil. There is no records of this motor ever being opened up and I purchased it from its original owner with 12K miles. The carfax showed all of the maintenance that's been done on it and no mention was made of anything that could remotely involve opening the head. So, that's why I'm just wondering what that stuff is. To me, personally, it looked like grey anti seize but since its an oem thing, it could very well be thread locker or something else all together.
Old Jul 27, 2009 | 05:06 AM
turboteg2nv's Avatar
It's probably Hondabond or assembly lube. Hondabond is used for everything on Honda engines.
Old Jul 27, 2009 | 09:26 AM
sirsol66's Avatar
Hondabond on the threads of a bolt???
I use the stuff for things like valve covers and such, never on bolts for any reason. Do any manuals specify their use for stuff like this?
Old Jul 27, 2009 | 09:36 AM
mugen88crx's Avatar
No, we don't put anything on any high torque bolts pertaining to the head assembly etc. This is coming from our Acura tech of 23 years.
Old Jul 27, 2009 | 09:39 AM
Just a guess based on your description. Check the Helms manual, see what they recommend to use (if anything) when reinstalling cam cap bolts. I'm guessing it was some form of Loctite, wouldn't make sense to use anti-seize lube in the head like that. Besides, anti-seize lube is the "tin man" lube. Does it look like that?
Why are you building an A3 head anyways?
Are you going FI?
Old Jul 27, 2009 | 04:19 PM
hawaiiancb74's Avatar
those bolts are not ment to have anythign on them, if they did it could have been something they use in the assembly process as honda does have certain process that they use during orginal assembly. ive never used anytype of anything on those bolts.
typesguy
Apr 26, 2012 12:47 PM
93LudeVtec
Jul 21, 2008 05:07 AM
standbackimapro
Dec 21, 2005 05:20 PM
hybrid1990crx
Aug 1, 2005 09:58 PM
b20b
Mar 3, 2002 11:46 AM
