Sparking at -Terminal Wire and Chassis
Old Jul 23, 2009 | 05:09 PM
loosestring's Avatar
Default Sparking at -Terminal Wire and Chassis
When I start my car I'm getting a spark at the connection between the negative battery cable and the chassis. I removed the bolt and tried to clean it up some as it's a bit rusty and also the connector on the end of the cable. Still it sparks.
What might cause that?
Old Jul 23, 2009 | 05:20 PM
ek-g6's Avatar
Default Re: Sparking at -Terminal Wire and Chassis
Did you try sanding down the part where the ground wire meets the chassis?
Old Jul 23, 2009 | 05:25 PM
Not on the chassis itself. I just used a battery terminal cleaner on the bolt and the wire loop connector. I'll have to try sanding on the chassis. Or maybe just brush it with the terminal cleaner too.
snzh22
Jan 10, 2009 05:11 PM
dpdawson
Honda Civic (2001 - 2005)
Dec 1, 2008 09:17 AM
AmauryR
Feb 20, 2008 12:43 PM
Mavrick
May 9, 2006 12:56 AM
egctreg
Jul 20, 2005 03:39 PM
