Air Condition issue
Old Jul 23, 2009 | 12:22 PM
lhd dc2's Avatar
Default Air Condition issue
Its a 94 Civic DX and my A/C will work one minute and then it will just start blowing hot air. Then after 10-15 min it will kick back on cold. When its blowing hot air, the condensor fan is not spinning. All fuses are good and freon is full.
Does anyone know what I should check or possible change?
Thanks
Old Jul 23, 2009 | 01:08 PM
ek-g6's Avatar
Default Re: Air Condition issue
I would check the realys, if not that pressure switch could be bad.
Old Jul 24, 2009 | 07:44 PM
lhd dc2's Avatar
up
Old Jul 24, 2009 | 07:55 PM
shawn_crx's Avatar
Fan not on.... your AC will not turn on...
Old Jul 24, 2009 | 08:08 PM
Former User's Avatar
Does the compressor clutch also disengage when the A/C stops blowing cold? If so, try jumping the pressure switch connector and then the thermostat connector when the A/C won't blow cold.
Old Jul 25, 2009 | 11:15 AM
lhd dc2's Avatar
Im not sure about the compressor clutch, and where is the pressure switch? Ill give that a try when it happens again.
Old Jul 25, 2009 | 12:06 PM
You should hear a click sound when the clutch engages or disengages. The engine will also idle up or down when the clutch engages or disengages, respectively.
Dual pressure switch:
Old Jul 27, 2009 | 03:44 AM
lhd dc2's Avatar
The compressor clutch doesnt engage when its not working or blowing cold.
Thanks for the detailed pic. I will try jumping the switch. What am I looking for?
Old Jul 27, 2009 | 06:16 AM
madaznkid115's Avatar
bump ?
here's a thread on AC's:
https://honda-tech.com/forums/honda-accord-1990-2002-2/constant-air-conditioning-problems-2595103/
i have a similar problem with my AC. When it works, it works fine. But when it gets too hot in the car, my AC just won't blow cold air. I don't even think the compressor starts to run. I think it may be the internal thermostat sensor switch.
What do you guys think?
Old Jul 27, 2009 | 01:13 PM
lhd dc2's Avatar
^ sounds very familiar.
Old Jul 27, 2009 | 01:22 PM
The compressor clutch doesnt engage when its not working or blowing cold...I will try jumping the switch. What am I looking for?
Look for whether jumping the connector allows the A/C clutch to engage when it previously wouldn't.
Old Aug 3, 2009 | 12:21 PM
lhd dc2's Avatar
I got a chance to jump the connector today. Nothing happened.
Old Aug 3, 2009 | 12:38 PM
SiRkid1's Avatar
bump also having issues with my ac
Old Aug 3, 2009 | 01:15 PM
Does the condenser fan also fail to run when the A/C won't blow cold? Try doing the same test that I mentioned for the pressure switch on the A/C thermostat (thermoswitch) connector on the evaporator.
Old Aug 3, 2009 | 01:29 PM
lhd dc2's Avatar
The condensor fan does work also. Okay I will give that try.
Thanks.
Old Aug 3, 2009 | 02:52 PM
I think you meant to say that the condenser fan does NOT run when the A/C blows hot and the compressor clutch won't engage, right?
Old Aug 3, 2009 | 05:53 PM
lhd dc2's Avatar
Right! damn typo.
Whats the easiest way to locate the thermoswitch your speaking of? Its different from the one that goes to the radiator hose correct?
I also noticed that when its real hot outside around 80-85 degrees, thats when it doesnt engage and work. It likes to be nice when its around 70-75 degrees and late nights.
Old Aug 3, 2009 | 05:58 PM
89CBR's Avatar
good thanks for the information my a/c doesn't work either....
Old Aug 3, 2009 | 08:15 PM
See diagrams below. If the switch turns out to be fine, then the heater control panel might be bad. This is a common problem of 5th generation Civics.
Old Aug 4, 2009 | 12:15 PM
thanks, I'm also going to try and test and/or bypass those switches soon.
Where did those diagrams come from?
also, if this a/c problem is such a common problem of 5th gen civics , then why is it hard to find info on how to fix it?!
Old Aug 4, 2009 | 12:39 PM
I have read several threads on the forum where a person's A/C won't work in hot weather, and the problem turned out to be a bad heater control panel (circuit board). You may want to do more searches for such threads. Click here for one member's experience that I could find.
Old Aug 4, 2009 | 04:48 PM
lhd dc2's Avatar
I think my ac/heater control panel might be the problem. When it went hot on me, I tried banging on it and cold air came right back on. I also have to bang on it at night to get my lights to come on , so it might just be a bad unit.
Thanks for your help RonJ!
Old Aug 10, 2009 | 06:59 AM
yeah thanks man!!!!
http://honda.lioness.googlepages.com/airconditioning
this page was reallllly helpful.
I opened up my dash and pulled out my heater control panel (pain to get out). And when I got to the circuitboard, I found that the solder joints were all cracked - which means my A/C button didnt work! I soldered it back together nicely (i have pics if u wanna see) and i recharged my A/C.
So hopefully, this week i'll experiment and see if my a/c works better in hot weather.
jdwheat1
Nov 24, 2012 11:03 AM
LeniX
Dec 15, 2008 12:14 PM
JDM_SOHC
14
Aug 15, 2005 09:04 AM
devilpuppy
Jun 11, 2005 08:34 AM
Cjsls
Sep 29, 2004 02:14 PM
