Transmission & Drivetrain Gearboxes, Differentials, Clutches
cracked tranny casing
Old Jul 23, 2009 | 08:43 AM
rick_rabies's Avatar
I'm not Rick!
Default cracked tranny casing
hi, 99 si b16 tranny
has alot of stress cracks. 1 crack in particulor leaks oil from the gears.
can i just weld the crap out of this. id be like a spider web after im done
or can i get a new casing? i was thinking about that but can i buy just the casing new from somewhere?
Old Jul 23, 2009 | 12:44 PM
NLR808's Avatar
Default Re: cracked tranny casing
i ended up getting a new bell houseing for my tranny since the motor mount studs striped out and i was had jb weld holding them in wich was scary for a few days till i changed it
i used a ls bell houseing side i got from some one (only to find out someone had used the wrong size bolts for the stock mount on the front of the tranny and cracked the case so i used my friend jb weld again)
but judging by the qestions your asking do some research on how to do it its kind of a pain to do http://articles.evans-tuning.com/200...-differential/ start with that
Old Jul 23, 2009 | 01:07 PM
Aquafina's Avatar
You can get a new case from Honda, or look around for a used case. You'll need to shim the diff and mainshaft.
Welding it will likely warp it.
Old Jul 30, 2009 | 04:50 AM
I'm not Rick!
where can i order a new casing? honda? majestic honda or somewhere else?
Old Jul 30, 2009 | 08:29 AM
pgpbubble's Avatar
You dont need a new case; check your other thread. Its normal casting marks.
Old Jul 30, 2009 | 08:34 AM
I'm not Rick!
no these are casting cracks. if i had a better camera you could tell. ive seen casting cracks. oil doesnt drip from casting cracks the metal is shifted and metal flakes come off.
zjbunch30
Honda S2000
Apr 24, 2011 04:55 PM
creepass
Jul 4, 2009 05:13 PM
cincispeedemon
Oct 10, 2004 02:50 PM
Ransom
22
Mar 15, 2004 04:06 AM
cr-x si
16
Jun 19, 2003 09:13 PM
