Turbo for a 350whp d16?
Old Jul 23, 2009 | 12:50 AM
joppe's Avatar
Default Turbo for a 350whp d16?
Im aiming for 350whp with d16 and im thinking what turbo should i get? Im thinking maybe somekind of holset, maybe hy35 or hx30? Garrett t3/4 or borg warner like this
http://fjdistributors.com/product_in...roducts_id=327
Is this too laggy for street D? Whats your opinion?
Old Jul 26, 2009 | 08:54 PM
boostedEF91's Avatar
Default Re: Turbo for a 350whp d16?
garrett t3/t4 57 trim. or borg/bullseye 57trim
Old Jul 26, 2009 | 09:01 PM
TheShodan's Avatar
Moderator
What's your budget? Journal or ball-bearing cartridge? 350whp on pump gas? What is your compression ratio? There are a few choices for this. Let us know first.
Old Jul 27, 2009 | 10:51 AM
joppe's Avatar
Im going with holset hy35. Bullseye t3/4 i was thinking first but found hy35. Compression 8.5 and pump gas maybe future e85.
Old Jul 27, 2009 | 10:54 AM
i made 300 on 14psi with my single cam before. had a zex 59300 cam in it with vitara's and the bullseye 57trim. coulda made alot more but then i went to a b series.
Old Jul 27, 2009 | 11:04 AM
HiProfile's Avatar
The Hy35 will be enough, but may be a bit laggy. You'll want to do something to the IM or head, besides the obvious cam, to help upper-rpm power. An EX trans with a ZC gearset would help too. The idea setup would be an hx35 with a matching divided manifold.
Honestly, 350whp is far more than you need on the street. I can see if it's a street/strip car, but less lag is usually more fun than more power when you're on the street. You could max out a 50trim t3/t04e for 350whp in a built sohc, and wouldn't have as much lag to deal with.
Old Jul 27, 2009 | 11:59 AM
joppe's Avatar
Im maxxed out t28 and want more power. I used to have PTE sc50 with .48 exhaust. I boosted 27psi and it was pretty good, maybe 20hp more and i would call it a day. But motor had head failure and it smashed turbo.
Old Jul 27, 2009 | 12:30 PM
TheShodan's Avatar
Moderator
Well, the Bullseye Power unit is nice, but uses a larger exhaust wheel than the ones garrett uses. The slightly larger T3 and GT journal bearing ones work a bit better for the d-series.
Old Jan 11, 2010 | 01:48 PM
sadmind's Avatar
how laggy will be the hy35?
AFAccord
Sep 19, 2012 08:55 AM
turbosol94
Jan 14, 2009 06:20 PM
browning
Aug 5, 2007 07:02 PM
phatrick2332
Jun 10, 2005 05:05 PM
rexinfection
Nov 15, 2002 09:15 AM
