QUESTION ABOUT THERMOSTAT !
Old Jul 21, 2009 | 11:07 PM
JAYDmManny1331's Avatar
Default QUESTION ABOUT THERMOSTAT !
so i changed on of my hose of the radiator the lower one and i put the coolant in made sure no air in the system then i left it on for like 10 min then the top hose got hot kinda hot and the bottom one was still warm and then i took it for a drive and drove fine i hit boost and stilll fine then i got home driving slow and started overheating agan then the needle stayed like 3/4 of the way to the H and both of the hoses were kinda hot do you guys think its my thermostat thats bad ???? need help !!!!!!
Old Jul 22, 2009 | 05:07 AM
fcm's Avatar
fcm
Old Fart
Default Re: QUESTION ABOUT THERMOSTAT !
Pull the thermostat out and see if engine runs hot without one. 94
Old Jul 22, 2009 | 07:41 AM
and also i took it for a drive out today and then needle was just at half and i turned on the heater full blast and it keeped it a little bit under just perfect does that mean my fan isnt turning on when its suppose to
Old Jul 22, 2009 | 12:04 PM
Mikey3000's Avatar
did you fill it to capacity? you need to heat the car up till the t-stat opens and top the radiator off.
Old Jul 22, 2009 | 03:48 PM
im taking the thermostat out today and jumping the fan hopefully that solves my problem !
Old Jul 22, 2009 | 06:15 PM
fcm's Avatar
fcm
Old Fart
Using the heater will always help drop engine temperature.
Have you checked to see if your rad fan is on, [running] when gauge indicates engine temp. is high?
Overheating only when stopped or moving slowly is an indication of a rad fan not working, at speed there is enough air movement that the fan is not needed. 94
Old Jul 22, 2009 | 09:07 PM
so i took the thermostat out today and my fan works fine i can hear it but my heater hose was leaking today so i guess i now have to change that one hopefully thats the last problem because fan works the thermostat is out and i bled it already !!
Old Jul 23, 2009 | 05:31 AM
fcm's Avatar
fcm
Old Fart
Does it still run hot with thermostat out?94
Old Jul 23, 2009 | 07:43 AM
well it was running fine then it overheated so i checked and the heater hose popped and leaked alot of coolant could that be why it over heated again
EGcivic_95
31
Jan 29, 2011 06:09 PM
vlude99
Jul 30, 2009 05:58 PM
jwlee7ucla
Aug 7, 2007 03:48 PM
twenty
Jul 21, 2005 04:32 PM
twenty
Jul 21, 2005 08:36 AM
