bolt keeps turning
Old Jul 21, 2009 | 07:06 PM
00DC2's Avatar
Default bolt keeps turning
i was trying to remove a bolt but it just keeps turning. it hasnt moved at all
how would i go about trying to remove this. thank you.
Old Jul 21, 2009 | 07:08 PM
totsie7944's Avatar
Default Re: bolt keeps turning
which bolt? It sounds stripped which means you may have to drill it out. but we need more detail
Old Jul 21, 2009 | 07:20 PM
00DC2's Avatar
its one of the three 10mil bolts in the engine bay that hold the fender on a 3rd generation integra
Old Jul 21, 2009 | 07:32 PM
srmofo's Avatar
Im not familar with those bolts but usually when that happens it means the nut broke off of the other side. Its usually welded on. you have to cut a hole to get in there and put a wrenck or socket on it to hold it. or find some other way to get in there with a tool. If you have acces to air tools and its not to tight, sometimes you can zip it off by giving the tool a quick spin and releasing, repeated several hundred times.
You can also try grinding the head off of it and punching it through
Old Jul 22, 2009 | 05:21 AM
fcm's Avatar
fcm
Old Fart
Ditto the above,^^^
Nut in chassis has come loose and is spinning with bolt, best way to remove bolt is to use a butterfly impact gun, as mentioned use quick short "burps" of tool.
You can also try tapping a wedge, [flat screw driver] between fender and chassis, [not too tight] next to bolt and turning bolt and then taping wedge in a little more and so on until bolt comes out. 94
Old Jul 22, 2009 | 06:18 PM
00DC2's Avatar
thanks chiefs
joevtoo
Jul 3, 2014 04:45 PM
tpot90
Apr 5, 2008 09:46 AM
truevietluv636
11
Jun 6, 2007 07:13 AM
Methane2k2
Dec 15, 2004 12:57 AM
Shocka1998LX
Aug 22, 2004 05:11 PM
