tranny selection for 300whp d16
Old Jul 20, 2009 | 01:04 PM
j0keefe21's Avatar
Default tranny selection for 300whp d16
so i currently have a dx tranny and i was wondering if im going to need a ex tranny to handle the power? i dont know of any differences besides gearing but hopefully someone can shed some light for me. thanks guys
(94 honda civic)
Old Jul 20, 2009 | 02:02 PM
94EG8's Avatar
Seagull Management
Default Re: tranny selection for 300whp d16
EX/Si trannys also have larger bearings for the differential carrier bearings (IIRC the mainshaft bearings are also larger)
Old Jul 20, 2009 | 02:24 PM
redracerk20's Avatar
stay with the dx tranny! it tops out at 175 mph
Old Jul 20, 2009 | 02:54 PM
mattliston's Avatar
even 300whp wont ever make use of it. his best bet is the EX tranny. even then, top speed is un reachable with 300whp
Old Jul 20, 2009 | 03:36 PM
j0keefe21's Avatar
alright sounds good. i knew the ex tranny could hold alot of power but wasnt sure as to why. with the closer gear ratio am i going to have to worry about beating the crap out of my turbo on 80+mph highway cruising.
Old Jul 20, 2009 | 05:36 PM
ekhatchling's Avatar
The difference at cruising on 5th at 80mph is a few hundred rpms if this calc is correct. Ur turbo wont be on higher boost if that's what ur worried about. Besides, U can adjust how much boost u are on with ur throttle.
http://www.zealautowerks.com/transcalc.php
If ur serious about how much your tranny can "handle" have it rebuilt by gearspeed. But for everyday street, stock tranny is fine as long as your clutch can handle it.
Old Jul 20, 2009 | 05:56 PM
user 98292739's Avatar
you can be at 150 mph and still not be in boost...
boost is related to throttle preassure.
Using a DX tranny or by saying its better is saying being in boost longer is better...thats all bs...closer gearing is faster....
but the longer gearing is good for 500+ hp when you need gearing for traction.
Old Jul 20, 2009 | 06:18 PM
j0keefe21's Avatar
ok thanks guys. learn something new everyday!
Kyles ej1
Aug 19, 2004 06:05 PM
JDMlyfestyle
18
Jun 17, 2003 10:21 PM
darkracer
Feb 11, 2003 03:23 PM
turbod16y7vtec
Dec 12, 2002 09:22 AM
