reassembling tranny - too much gasket former?
Old Aug 23, 2002 | 06:29 AM
serious's Avatar
Default reassembling tranny - too much gasket former?
i put my tranny back to gether last night using honda's ultra flange II gasket form and put ont he suggested amount, but when i tightened the two halves together, a good bit squeezed out from between the two halves, and i'm assuming quite a bit squeezed out on the inside as well. is this a risk to the tranny? can those pieces break off and hurt stuff? should i break it appart again and reassemble it with less gasket former?
also, it took me almost 30 minutes before i was able to get the two halves together. was that too long?
[Modified by serious, 10:34 AM 8/23/2002]
Old Aug 23, 2002 | 10:25 AM
keithv's Avatar
Default Re: reassembling tranny - too much gasket former? (serious)
i don't know of the honda gasket former, but i have had the hondabond squeeze out on me some when putting the two tranny halves back together. a small amount has always squeezed out, so it was never much of a concern for me.
depending on how much squeezed out, you might want to separate the halves again and reseal with less gasket former. i know the ring gear on the diff sits pretty close to the edge of the tranny case.
Old Aug 24, 2002 | 12:50 AM
Mista Bone's Avatar
D Tranny Guru
paper thin layer on ONE case half. The cases are machined that good!
One tube of HB4 will do 75-100 trannys if it doesn"t dry up.
B16Jacques
Mar 8, 2007 03:31 PM
EG2Driver
Nov 1, 2006 07:23 PM
civiccrazy93
Nov 1, 2004 07:36 PM
integraGSR213
Feb 16, 2004 04:54 PM
Muckman
Mar 5, 2003 05:32 AM
