misfire #2 fixed!! but hesistation around 3.4 - 4k
Old Jul 20, 2009 | 03:11 AM
CUTTERSPOOL's Avatar
Default misfire #2 fixed!! but hesistation around 3.4 - 4k
Past couple weeks I had problem with code PO3044 (Misfire #2).
First, changed spark plug, spark plug wires, caps, and rotors. Next, I did a value adjustment and oil change to see if the check engine light would be fix. Still no luck.
After, I took the value cover off and check my timing. My timing was off by a teeth. I checked my head and it seem the value was bent on Cylinder 2. I replaced the head gasket and slapped a b20 head also. I put everything back together and the check engine light went away. So that's fixed..
Now, I drove it around town and the car drove nice. I slowly took the car up to 4k but around 3.5 - 4k, the rpm will spike.
Note. When I pulled the spark plug wire out, one of the metal piece popped out and got stuck to the spark plug.
Im typing this on a sidekick so bare with it.
Any help?
Mad Third Gear Vtec
Jul 18, 2009 09:02 PM
ls6
Nov 25, 2008 08:45 PM
lewzor
12
May 22, 2008 05:09 PM
hatchboiracer
Nov 15, 2007 04:10 AM
turbotime
Oct 20, 2006 09:26 PM
