Transmission & Drivetrain Gearboxes, Differentials, Clutches
Difficult to put in reverse
Old Jul 19, 2009 | 08:15 PM
baller status's Avatar
Default Difficult to put in reverse
Why on every Honda / Acura I have ever owned is it hard to put it into reverse? Can anything be done about it?
Also, the shifter rocks forward hard when I let off the throttle suddenly. Is this a tranny issue or an engine mount issue?
Old Jul 19, 2009 | 09:40 PM
vanny_david's Avatar
Default Re: Difficult to put in reverse
This always happens all the time with my 97 LS with GSR Tranny
I already put into 1st and then back to Reverse.. and makes no differences
Old Jul 19, 2009 | 11:44 PM
rea1ist's Avatar
^^ i have the same problem and now my reverse lights dont work (checked all wiring, bulbs and fuse and its all good)
Old Jul 20, 2009 | 05:35 PM
Well it's not a major problem, just an annoyance. This happens on my wife's 01 Civic EX and my 97 Integra GSR. It was a problem on my previous 92 Integra LS and my previous 92 Civic with a JDM LSD SOHC trans. You put it in reverse and it doesn't quite click in solid, then you let out the clutch and hear that it's not gear.
I know that reverse is straight cut but there's no way that these cars had this issue when they were brand new.
Old Jul 21, 2009 | 08:56 AM
My car has been swapped from automatic to manual
so I can't tell whether the car has issue when brand new
Old Jul 22, 2009 | 08:39 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
if going from 1st to reverse doesn't help, try putting it in 1st, letting the clutch out a little so you can feel 1st gear load up, then slide it into reverse.. works everytime!
Old Jul 22, 2009 | 11:46 AM
Honda Bull's Avatar
B-series and reverse is like that. No fix, and yes, they most likely did it new.
Old Jul 23, 2009 | 08:41 PM
Gearspeed-Performance's Avatar
A lot of the Honda transmissions don't utilize a synchro for Reverse and rely on an idler gear to engage reverse..causes a lot of frustrations in Honda Owners!!
The ones that do..well you may have ran the trans low on fluid and heated up the Reverse assembly..that will intern cause problems since they will not operate smoothly. Seen it happen quite a bit!
Old Jul 24, 2009 | 09:18 AM
HONDRETTI's Avatar
i have trained myself to shift into 4th, then reverse. eliminates the problem.
Old Jul 25, 2009 | 10:17 PM
My Reverse problem has been fixed..
Found out to be a toasted shift rod
now I have no problems shifting into reverse with 100% accuracy and no hard shift at all...
Old Jul 26, 2009 | 03:57 PM
Honda Bull's Avatar
^^^ Do you mean the shaft which exits the trans that the linkage bolts to, or are you referring to the 5-R shift fork?
And in either case, what the hell did you, or a previous owner, possibly do to mess that up? lol
Old Jul 27, 2009 | 06:34 AM
TheAsian's Avatar
Honda transmissions use a straight cut non synrco revearse gear, so when you shift into revears a arm drops allowing a reverse idle gear to drop straight down and engauge the reverse gear. This normal for over time wear from the straight cut non syncro gear to wear slightly causing it to get slightly harder to go into reverse. Never force the car into reverse because then you will damnage the shift fork and possibly the gear.
Now as for the shifter rocking I would check the rear motor mount off the T bracket and your front tq mounts. More than likely your rear motor mount is worn and need replaced
micr0m0nk
May 30, 2006 06:08 PM
Plugs
Jan 10, 2005 07:21 PM
Plugs
Jan 9, 2005 04:56 PM
UNDER PRESSURE
Dec 6, 2004 11:49 AM
