Bend crank can be fix?
Old Jul 19, 2009 | 12:53 PM
maxogsr's Avatar
Default Bend crank can be fix?
I had a bad luck last week... Comming back from a trip, everything was fine and then the car felt slowdown by it self for 1-2 sec... It felt like I had hit something on the road... Then after 5 mins, I started hearing weird noise like a water pump that was failling out! So I pull over and pop the hood and find out that my A/c pulley tensionor had felt down... It was sitting on top of my crank pulley... Really bad...
Then after taking out pulley and broken nut, cut the a/c stap, everything looking fine so I start back the engine, and notice there was a little wabble on the crank pulley... So the next day I switch the crank pulley for an other one and the wabble is still there...
I guess my crank probably take the shot... Or could I have get lucky and it's only the crank's pulley nuts? I did 120 miles since then and this morning I check the vtec solenoid filter for metal residu but there was none...
If the crank is bend, can it be fix or I'll have to change for an other one? Is it possible to mesure the crank properly without taking out the block from the car?
This is bad....
Old Jul 19, 2009 | 04:04 PM
fcm's Avatar
fcm
Old Fart
Default Re: Bend crank can be fix?
I would be very surprised if you could drive your car 120 miles with a bent crank shaft, also not sure how it would get bent just because an idler pulley fell off, but I guess anything is possible.
Any good mechanic should be able to tell if it is bent or not without pulling it out. 94
Old Jul 20, 2009 | 02:21 AM
maxogsr's Avatar
Originally Posted by fcm
also not sure how it would get bent just because an idler pulley fell off, but I guess anything is possible. 94
When I took out the pulley, there was a little chip missing on the alternator row, engine side... that makes me thought that the bolt that hold the idler pulley or worst, the pulley it self could have got squeeze and then poped out between engine and crank pulley... I don't know, but this thing just scared me a bit right now... I was really like WTF! when I poped the hood when it happen...
What signs should I looked for for a bend crank... It's not something that happen everyday...
Old Jul 20, 2009 | 05:47 AM
fcm's Avatar
fcm
Old Fart
I will check with the mechanic at E Street auto today, [shop next to ours] 94
Old Jul 21, 2009 | 04:25 PM
maxogsr's Avatar
No one knows if a bent crank can be fix? Or if a little wabble on the crank pulley is common?
Old Jul 21, 2009 | 07:38 PM
srmofo's Avatar
how bad is this wobble? They usually have some movement to them.
Old Jul 21, 2009 | 11:55 PM
locash's Avatar
If the crankshaft were actually bent, it should be tossed into the trash.
Old Jul 22, 2009 | 04:44 AM
fcm's Avatar
fcm
Old Fart
OK, I spoke to the mechanic and he said your crank is not bent, if anything just the end if it, [end past the front bearing and seal] may have been bent and as long as it is not to bad, [noticeable vibration] don't worry about it, keep an eye on any belts for ware on the sides of the belts, if none don't worry about it, it is not worth "fixing", [not repairable without removing]. 94
Old Jul 23, 2009 | 02:19 AM
maxogsr's Avatar
ok, so far it seems ok... I went to the track and shake the car a bit and everything seem to run fine... Thanks for helping! If anything bad happien I'll posted it!
Old Jul 23, 2009 | 04:41 AM
B6tPoweredMx3's Avatar
There is a woodruff key in the end of the crank correct?
How did the slot where the key sits in look..
Old Jul 26, 2009 | 02:54 AM
maxogsr's Avatar
It look fine, no sign of damage, no loose... I did an oil change yesterday and look for metal inside oil filter and on my magnetic plug and so far nothing...No weird noise or lost of power so far.
I'm going lapping monday, next saturday I have soloII and the day after, we're doing a school/lapping day, so I'll keep an eye on it...
devilpuppy
Aug 30, 2024 09:15 AM
j4s0n1337
May 25, 2011 01:35 AM
civikdude
Feb 13, 2009 02:17 PM
DARKTEG_
Aug 13, 2006 03:15 PM
geldingmakr
Aug 3, 2004 10:51 AM
