Anything to do the tranny to beef it up? 3rd Grinds =P
Old Aug 23, 2002 | 12:21 AM
Ri5e's Avatar
Default Anything to do the tranny to beef it up? 3rd Grinds =P
I was wondering if there are any aftermarket parts like syncros or something for B series transmissions that would make it beefy? My 3rd gear grinds and sometimes its hard to put it into 4th. I know if I get another LS transmission I'm gonna run into the same problem down the line...
And I know a lot of other people who have the same problem with their 3rd gears with turbo cars.
Should I just get a GSR Transmission? From what I've heard, they are stronger and can handle more of a beating.
It's kind of embarrasing when I race and can't get it into 4th and I just rev in neutral for 2-3 seconds....
[Modified by BG Boost, 9:22 AM 8/23/2002]
Old Aug 23, 2002 | 02:05 AM
Kamin's Avatar
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (C-man)
Once ur tranny starts grinding..its going to happen more frequently. After those syncros start wearing down there's not much to do...either get a new tranny or replace them. Only problem is Honda does not just sell the syncro by itself..you have to purchase the entire gear like entire 3rd gear and 3rd gear syncro. It will be very costly.
An easy way to hopefully fix your problem is change ur tranny fluid. Make sure you use the proper weight.
Or sometimes it could be the pressure plate...i've seen people use cheap *** P/P and it causes the tranny to grind when speed shiftin.
only use honda MTF.
Old Aug 23, 2002 | 02:18 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (KAMiN)
Hmm, I could have sworn I bought a synchro by itself.
art
Old Aug 23, 2002 | 04:57 AM
RGAZ's Avatar
New User
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (BG Boost)
Actually, you are probably grinding due to the shift forks being worn. Replacing the forks with new ones will fix the problem until it wears again. The key to the problem is that the forks are a cheap aluminum that wears really fast on the sliders. I considered having some made out of titanium, but the quote I got made me sheet my pants.
pull the tranny, crack the case, replace all the bearings while you are there, replace the forks, replace the synchros. Good to go.
Parts cost, about $200, but a new tranny, priceless.
You can buy synchros by themselves. The rebuild kit for the tranny can be had for $160 from tranny rebuild places.
Randy
Old Aug 23, 2002 | 07:38 AM
Ri5e's Avatar
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (RGAZ)
I heard the syncros are like $15 each.
Old Aug 23, 2002 | 08:03 AM
SyndicateEH's Avatar
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (Arturbo)
art
I'm sure you can, http://www.transtarindustries.com/home.htm offers tranny rebuild kits, that include syncros repair kits. Give them a lookup , that is where i plan on getting my parts to do my tranny rebuild.
Old Aug 23, 2002 | 08:17 AM
DamonBoost's Avatar
New User
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (SyndicateEH)
I have a LS Tranny that has just been gone through and the only gear set that needed to be replaced was 2nd, So basically its brand new. They had to replace some seal as well. I also had a quaife installed as well. Still brand new. Its yours for $1400 bucks. Bascially a brand new tranny with quaife.
Old Aug 23, 2002 | 08:39 AM
jinxproof99's Avatar
New User
get a gsr tranny.
Old Aug 23, 2002 | 10:23 AM
Rain_man's Avatar
New User
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (jinxproof99)
get a gsr tranny.
It'll fix your grinding problem and you'll get a performance upgrade to boot.
Old Aug 23, 2002 | 11:35 AM
Scott - 93HB Si's Avatar
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (DarksideDC4)
I wish I had read this post last week...My COMPLETE (since honda doesn't sell just the syncro) 3rd gear (including syncro) came for my B16A tranny yesterday. It cost me about 450cdn! And I also got all new bearings for the tranny. Will be installing the quaife this weekend!
[Modified by Scott - 93HB Si, 3:35 PM 8/23/2002]
Old Aug 23, 2002 | 12:01 PM
canuck-mx6's Avatar
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (Scott - 93HB Si)
Me too, although I am happy with my ITR tranny, I had the grinding third gear syndrome in my GSR as well. I sold it ensuring that the buyer knew that the tranny grinded at high RPM.
Old Aug 23, 2002 | 01:54 PM
E Swift's Avatar
Default Re: Anything to do the tranny to beef it up? 3rd Grinds =P (canuck-mx6)
It doesn't matter what tranny you have if you own a Honda. 3rd gear sucks on b-series tranny's. When I had my LS transmission, it was always tougher to get into 3rd gear, and now with my GSR tranny, its still the same.
Old Aug 31, 2002 | 01:59 AM
Arturbo's Avatar
Better than steak
25 Year Member
I have bought OEM sychro by itself here at my dealership.
art
Old Jun 10, 2003 | 09:01 PM
LSpimpTEC's Avatar
how much did the synchro cost alone at your dealership? just to get an idea.
MrExclusive
Feb 4, 2010 07:52 AM
VTECcnIT
Feb 25, 2006 12:12 PM
OliGSR
May 27, 2005 06:14 PM
fangtl
Oct 4, 2003 06:19 PM
maxpsi
Jun 16, 2003 01:40 PM
