Why does my #$@! BRAKE light stay on??
Old Aug 22, 2002 | 11:36 PM
bustaman0763's Avatar
Default Why does my #$@! BRAKE light stay on??
This morning i wake up and start the car up to go fill it up with some gas...
Put the key in the ignition, clutch to the floor, pull out of gear, put down the e-brake, and go to pull out of the driveway when i realize the word BRAKE is still lit up in bright Red on the dash...
so I mess around with the e-brake, pulling it up, and putting it down over and over, which makes no difference...
I pump the brake pedal, then pop the hood and check the brake fluid and find out that it is in good condition, right up to the MAX line.
Pulling down the block, tested out the brakes, and they work just fine, but when the car warmed after about 5 minutes of driving the BRAKE light went out.
I drove the car a couple of times today, and the same thing happens every time.
WTF is going on? Did some sensor go bad on me or something? I'm clueless... just looking for some insight...
Old Aug 22, 2002 | 11:41 PM
Tommy_Gunns's Avatar
Default Re: Why does my #$@! BRAKE light stay on?? (bustaman0763)
Take it to the dealer, they should be able to diagnose and fix your problem (if they are any good).
Old Aug 23, 2002 | 01:05 AM
AZTodaSi's Avatar
Default Re: Why does my #$@! BRAKE light stay on?? (Tommy_Gunns)
I have the same problem. I am running an OBD1 P28 ECU chipped to a P30, and I eventually just gave up. Doesn't seem like it does any harm, so oh well...
Old Aug 23, 2002 | 03:10 AM
gary201147's Avatar
I have the same problem too. Except the problem is that by the time you take it to the dealer the light goes off so they can't diagnose it. Let me know if you take it to the dealer.
Old Aug 23, 2002 | 04:46 AM
pleiades nutz's Avatar
Default Re: Why does my #$@! BRAKE light stay on?? (gary201147)
This just happened to me last week and it is a known problem according to my mechaninc. The Brake resevoir cap that has the sensor on it goes bad. He got a new one out and replaced in 5 mins. No more brake light.
Old Aug 23, 2002 | 05:03 AM
BryanSprinkel's Avatar
Default Re: Why does my #$@! BRAKE light stay on?? (nighthawkR618)
You can do one of 2 things. Unplug the cap, or replace it. If enough people start to complain about it, they might do a recall on them.
I unplugged mine for about 3-4 months. I just bought a new cap and the light has been off ever since. It was about $25-30.
G'luck
Old Aug 23, 2002 | 07:56 AM
TREVER's Avatar
Default Re: Why does my #$@! BRAKE light stay on?? (BryanSprinkel)
first make sure your brake fluid is full. The cap has a level swicth in it, you can jump the wires.
Old Aug 23, 2002 | 11:42 AM
Fugazi's Avatar
New User
Default Re: Why does my #$@! BRAKE light stay on?? (TREVER)
yeah this happened to me to...
Old Aug 23, 2002 | 12:15 PM
JoshRambo's Avatar
does the brake light have any thing to do with the bulbs maybe being burned out? i thought i read that somewhere.
Old Aug 23, 2002 | 02:36 PM
rs's Avatar
rs
According to my dealer there is a defect in some of the Tegs brake light sensor system. If you have checked your brake fluids, made sure no brake lights are out, etc... then take it to the dealer.
Old Aug 23, 2002 | 03:22 PM
Mai_CL-S's Avatar
New User
Default Re: Why does my #$@! BRAKE light stay on?? (rs)
happened to me too!! all i did was add break fluid and PRESTO! Never more..but it happens to MOST acura's my sisters 4 dr, friends legend did it so i'm guessing its common.
Old Sep 25, 2002 | 07:16 AM
mstewar's Avatar
mine started doing this yesterday morning.. only seems to be happening in the morning for some reason..
yesterday it did the stay on until about 1/2 way to work and then off the rest of the day(when it's supposed to be off).. today however, it kept coming on and going off until about 1/2 way to work and then decided it wanted to stay off..
didn't get to check the fluid, since I was running late, but i just filled it a couple weeks ago.. should be ok.. if it is, i assume this is a problem with the resivoir cap like the others?
Hondaddik
Suspension & Brakes
Jan 6, 2013 02:21 PM
Kennyjai
Oct 17, 2011 11:55 AM
soloIntegra
Sep 4, 2003 07:29 AM
94BlackRS
Nov 28, 2002 02:43 PM
Slow
Oct 29, 2002 03:38 PM
