98' integra won't start!
Old Jul 18, 2009 | 02:56 PM
heyimrchills's Avatar
Icon6 98' integra won't start!
my dad he put a new battery in for the car right when we bought it few weeks ago.. the car started and ran fine.. now sometimes the car will not start?
is it because the battery isn't properly mounted or??
help please
Old Jul 18, 2009 | 03:43 PM
hillbilly's Avatar
Default Re: 98' integra won't start!
Is there a loose terminal? Loose wire in the terminal? Loose battery ground?
Old Jul 18, 2009 | 04:28 PM
follie gatts's Avatar
does it try to start and not turn over or turning the key does nothing at all like no juice is getting to the starter?
the circuit is pretty simple, the positive terminal goes to chassis. the negative terminal runs to the starter and the fuse box.
Old Jul 18, 2009 | 09:45 PM
XxNampsterxX's Avatar
Umm....I think you have that reversed. Negative terminal goes to chassis and the positive goes to the starter and fuse box.
Old Jul 18, 2009 | 10:04 PM
jhammond_82's Avatar
Reject Papi
lol^^. if it turns over and doesn't start, might need a new main relay. i just replaced mine. its a hell of alot better than it letting me sit for 20 mins at a time now.
Old Jul 20, 2009 | 07:01 AM
oh ya.
Old Jul 20, 2009 | 07:50 AM
CUTTERSPOOL's Avatar
if you turn the key and it doesn't do anything but clicks. Your started might be crapping out. Try push starting it to see if it turn on like that.
Old Jul 20, 2009 | 12:09 PM
Evolution-93-Ex's Avatar
From: Your mommas bed, that might be true too ..., So Cali, USA
wow this is crazy my car is a 98 and kinda has that problem every so often it doesn't start, but i keep thinking its my battery, because i have a mini 8 lbs one. and sometimes i have to sit for awhile then turn it over and it will start
Old Jul 20, 2009 | 12:12 PM
BlackandMild's Avatar
I had a similar problem, make sure you check the under the hood fuses. It's the big one, forgot the number- think it was B something. I replaced this and everything was fine, sounded like the same creeping problem.
Old Jul 20, 2009 | 03:09 PM
Egpower88's Avatar
its looks right to me.. Does it even crank over?? if it does and its not starting then it could b your ignition coil going out.. its inside the distributor cost 40to50bucks..
Old Jul 20, 2009 | 09:52 PM
wow there's so many different variables, that i think it would be best to take it to a professional
Old Jul 20, 2009 | 10:10 PM
thanks for all the advice guys but i found out the positive just wasnt mounted all the way in aha..
tvdc2
Jul 29, 2016 08:48 AM
Honda_wannabe
13
Jun 9, 2010 03:53 PM
riouxB16T
Apr 17, 2008 06:24 PM
EnzoSpeed
Jun 7, 2006 12:44 PM
Moe
Nov 13, 2003 08:56 PM
