installing shift linkage
well it has a full h22a1 swap and the kid i traded with told me thats why shifting is hard and why its hard to find gears and evan move the shifter around .
in order to swap the cables, most ppl usually run them through the firewall, if that is the case for your sol, then you are going to need to take out your dash and everything.
if they made the hole through the fire wall then nope, you'll have to take the dash out for that one, if they ran the cables under the car then you can just swap them out, chances are they didn't do it that way.
I wasn't talking anything about what you said so no sense in getting smart, My statement was to the operator hints the reason I quoted him NOT YOU, look at where it was posted RIGHT UNDER HIS POST. That's why I was stating the H22 doesn't have linkages.
9k Swag
Aug 8, 2011 11:08 AM
da_driver_15
Dec 25, 2010 12:23 PM
