Faster power windows?
Old Jul 17, 2009 | 09:26 PM
iiPancho's Avatar
Default Faster power windows?
Got my power everything conversion done in my hatch.
But the passenger window goes up slow until it gets halfway up and then it speeds up.
Any ideas to get it to go up quicker. I already WD-40ed the **** out of the window tracks.
Old Jul 17, 2009 | 09:47 PM
skaternak's Avatar
Default Re: Faster power windows?
spray tracks with lithium grease i did that on mine, it works
Old Jul 17, 2009 | 09:48 PM
dhortz214's Avatar
try putting silicon lubricant instead on the rubber tracks, i heard that wd-40 is not good for it. if that doesnt help you remove the door panel then put some grease on the metal tracks.
Old Jul 17, 2009 | 11:33 PM
geneeunit's Avatar
yes, and make sure you tracks are aligned correctly.
Old Jul 17, 2009 | 11:34 PM
sanegb16's Avatar
jiggaloo
or oem honda silicon spray that stuffs amazing
Old Jul 18, 2009 | 12:02 AM
farkiller's Avatar
Lol mine does EXACTLY the same thing.
Old Jul 18, 2009 | 09:19 PM
iiPancho's Avatar
I sprayed silicone spray on it today, it worked really well.
could be a bit faster but, im not gonna be picky [:
Old Jul 18, 2009 | 09:30 PM
saullyboy21's Avatar
I have a 98 dx hatch and I have been wanting to do the conversion to all power as well, I know the easiest way is to buy ex doors but how do you go about wiring them up the right way?
Old Jul 19, 2009 | 10:07 AM
iiPancho's Avatar
I found a set of 99 si doors at a junkyard that were not the color I had, So I took the guts [power window regulators, actuators etc all of the harness out, I i put them into the doors already on my car.
I can send you a walkthrough if you need it.
Then I went to another junkyard and found an ex floor harness, the whole entire thing is plug and play, except you will have a few extra plugs because the ex had more options {fuel pressure sensor i think, moonroof etc.
Dont forget to get a power mirror switch, 3 20 amp fuses and a power window and lock relay. its pretty easy. the hard part is taking apart the entire interior.
I would take the carpet out too, it makes it alot easier.
Keeep on hand some electrical tape, soldering gun, zip ties and some wire cutters.
My ex harness had the seatbelt plug cut off, so i simply cut the one off my dx harness soldered it to my ex harness.
IF you need any help or anything Pm me.
Old Jul 19, 2009 | 12:01 PM
NOFX's Avatar
H-T White Ops
Silicone spray down the tracks.
White lithium grease isn't good for contacting rubber.
Old Jul 20, 2009 | 08:30 PM
iiPancho's Avatar
Silicone worked really good, what kinda grease should I put on the metal itself?
Old Jul 21, 2009 | 09:41 AM
NOFX's Avatar
H-T White Ops
Which metal? What point are you talking about lubricating now?
Old Jul 21, 2009 | 09:55 AM
H23_del_soul's Avatar
WD-40 is not good for that at ALL. That stuff eats rubber and metal over time. Google the long term effects of it on bolts and things
Old Jul 22, 2009 | 02:07 AM
dhortz214's Avatar
on the metal i just put some regular coastal grease. it seems to help along with silicon lubricant on the rubber tracks
Old Jul 22, 2009 | 07:43 PM
iiPancho's Avatar
The metal of the actual regulator itself, the teeth part were there is already existing grease.
Old Jul 22, 2009 | 07:47 PM
EGR95's Avatar
bump i have the same problem.
FL!P_G
Honda Civic (2001 - 2005)
14
Jul 20, 2007 01:00 PM
onekoop
13
Dec 19, 2005 03:10 PM
JDM*addiction
Jun 26, 2005 11:00 AM
00_whytehatch
Jun 1, 2005 10:06 PM
okman16
Sep 17, 2003 03:04 PM
