tranny??
Old Jul 17, 2009 | 01:13 PM
Egpower88's Avatar
Icon6 tranny??
Alright I got a b18c1 and I was replaceing the clutch and when I took off the tranny there was oil around the inside.. any clue what that can b??? My buddy told me it might b the crank seal.. help please!!
Old Jul 17, 2009 | 01:23 PM
mouab18c1's Avatar
Default Re: tranny??
was there alot of oil?
Old Jul 17, 2009 | 02:27 PM
94 ls-r's Avatar
Its either the tranny or the crank seal.
Old Jul 17, 2009 | 02:33 PM
da4lyfe's Avatar
its your rear main seal for the crank
Old Jul 17, 2009 | 04:48 PM
B16R-T's Avatar
it could be the seal from the mainshaft of the transmission check to see if the mainshaft has play that is the only reason those seals go out also the rear main could be going out take the flywheel off and replace it anyways it is quick and easy
Old Jul 20, 2009 | 02:55 PM
Egpower88's Avatar
Icon6 Re: tranny??
wheres the mainshaft locate at??
Old Jul 20, 2009 | 05:55 PM
94 ls-r's Avatar
The main shaft it the piece that connects the motor to the tranny.
Old Jul 21, 2009 | 07:29 AM
Egpower88's Avatar
What would I have to check on the main shaft?? Will I'm replacing the rear main seal and was jus wondering if the main shaft needs to b replace too..
Old Jul 21, 2009 | 08:28 AM
Targa250R's Avatar
be professional
Listen, where is the oil leaking from? Is it leaking from behind the flywheel on the engine, or is it leaking from behind the clutch release bearing on the transmission? Is it transmission oil or is it engine oil?
If it's leaking engine oil from behind the flywheel, then the rear main crankshaft seal is bad. Replace it.
If it's leaking transmission fluid from the transmission mainshaft seal, then you may have some bigger problems.
Sr420Det
May 11, 2010 11:09 AM
kixcrx
22
Nov 2, 2006 12:34 AM
eh3 93
Jul 24, 2006 08:04 AM
ITSTOCK
Aug 10, 2004 10:04 AM
White HB
Aug 2, 2003 06:42 PM
