**** GSR ROUGH STAGGERING IDLE*** HELP!!
Old Jul 17, 2009 | 09:59 AM
96MIDORIEK's Avatar
Icon6 **** GSR ROUGH STAGGERING IDLE*** HELP!!
Ok, let me start off with the symptoms:
Car idles rough and choppy like it is misfiring
when the AC is on, the car DIES at a complete stop
It is holding the correct idle (7-800 rpms)
Also when accelerating...the car SOUNDS as if it is missing up until 2-2.5k rpms although it does not RUN like it is
All in all...it sounds like I have a Turbo-back exhaust.....but no turbo to make the choppy tone.
Here is what I have checked so far:
-Pulled plugs. They are NEW NGK-R's and they were black on the end within a week
-cranked the car and pulled the IACV plug...it bogged down and died
-checked for broken vacuum hoses...and as far as I can see they are all ok.
-checked to see if I somehow switched the MAP sensor with the TPS sensor..and they were in the right spots.
-My wideband O2 A/F gauge is reading "stoich" when driving and "RICH" at idle
- Also, the little green plug on my VTEC solenoid was broken off...but I doubt that could be related to this problem.
This all happened when I took it to a local mechanic to have a freeze plug installed...and he went off and started running vacuum hoses and ****...and I only asked him to put on the freeze plug. I have a SK2 Pro IM, and some vacuum hoses were meant to be bypassed.
Any help here would be appreciated...I have been searching the web...and nothing seems to help me out.
*****NOTE...CAR IS RUNNING A CHROME CHIPPED P28 FROM PHEARABLE.NET*****
Old Jul 17, 2009 | 11:20 AM
HONDRETTI's Avatar
Default Re: **** GSR ROUGH STAGGERING IDLE*** HELP!!
you're def running super rich, sounds like your map sensor is hooked up wrong, if at all. i would take it back to the mechanic and ask him whats going on. check to see if you have a map sensor code too.
DelSolMarine
Oct 20, 2008 03:45 PM
panda_eh2
Dec 22, 2007 08:34 AM
bleedblue94
28
Sep 11, 2006 12:55 AM
upstate
Nov 26, 2004 09:21 PM
SpoolnG2
Jan 8, 2003 09:13 AM
