car stop pulling after 7000rpm
Old Aug 22, 2002 | 08:55 PM
rice4life's Avatar
Default car stop pulling after 7000rpm
the setup:
b16a
drag gen3
msd 6-btm set at .6 deg, msd blaster 3
3" dp back
dsm 450, vafc, turbo chip pr3. (pump not install)
apexi avcr
running 8 psi
the car pulls hard until 7000rpm then it just hit a wall. apex turbo timer a/f read 11 at full boost. am i getting valve float. i dont think its a fuel problem. both the apex and autometer a/f guage read rich. i dont have an exhaust restriction because it's 3" with 3" carsound cat. people tells me that the first gen b16a have weak valve springs. what do you guys think?
Old Aug 23, 2002 | 02:26 AM
niedejb's Avatar
Default Re: car stop pulling after 7000rpm (rice4life)
Too rich? I had the same problem and the a/f fell below the 8:1 mark on my first run.
Old Aug 24, 2002 | 09:34 AM
nekkedR's Avatar
Default Re: car stop pulling after 7000rpm (niedejb)
92siturbo.....i had the same problem at 5,000 rpms when i had the boost controller hooked up and set to 14psi. My friend seems to think i have fuel cut at 11.2 psi in my program for my hondata. It's also done it at 5500 and 4000 rpms. When i run it through the watsegate it pulls all the way to redline which is 8400 rpm.
slowasshatchy
Dec 26, 2012 10:19 AM
Lei Siew Long
Mar 23, 2004 09:22 AM
nigel
Aug 12, 2003 10:07 AM
_Shadow_
Apr 30, 2003 07:28 AM
turboedef9
Apr 29, 2002 09:27 PM
