VTEC problems
Old Jul 16, 2009 | 05:36 PM
brokeHonda's Avatar
Default VTEC problems
Well I've exhausted all avenues of fixing this problem and need some ideas. Motor is a 2L Ls/Vtec running OBD1. Distributor/Head is obd2 with conversion. The motor is in a '00 OBD2b teg running p28 with Hondata s200.
The problem is that the crossover does not happen until 6700 rpm. X-over is set at 5500 rpm.
Here is the laundry list of crap I've done to fix the problem:
1. Rewired entire loom (eg. grounds, vtec lines, distributor, etc..) All connections soldered!
2. Replaced ICM
3. Replaced cap/rotor
4. Ran different plugs/wires
5. Cleaned solenoid
6. Wired vtec directly to ECU bypassing conversion harness
Oil pressure is 50-60psi at rpm's. Head has a GE conversion. This motor was in a 92 EG and was getting x-over at 5500rpm. After recent tune the tuner set x-ver at 6500 initially with a final setting of 6000rpm. I lowered the setting via s200 incar to 5500rpm. The problem was still present before I lowered the x-over.
I will take any ideas at this point!
Old Jul 16, 2009 | 10:13 PM
delsolproblems's Avatar
Default Re: VTEC problems
Does the vtec always engage at exactly the same rpm? Did changing the vtec rpm have any effect at all? If no to both, check the coolant system. Either your computer thinks that 5500rpm is 6700rpm or the requirements for vtec aren't being reached until 6700.
Old Jul 17, 2009 | 03:33 AM
brokeHonda's Avatar
Vtec is engaging at 6700rpm everytime. That's what is getting me. For example, if it was based on say oil pressure it was activate at different rpms based on viscocity and pressure (cold vs hot motor).
What are the chances that the x-ver is "locked"? (ie. when the tuner initially set it at 6500rpm and it is still there)
Old Jul 17, 2009 | 03:34 AM
brokeHonda's Avatar
Coolant system is fine. Gauges (stock and aftermarket) are good and similar in reading. Motor has no air bubbles and fan kicks on when hot.
Old Jul 17, 2009 | 07:16 PM
brokeHonda's Avatar
alright, which route?
whole new distributor vs. another chip
Old Jul 18, 2009 | 03:38 PM
brokeHonda's Avatar
Anyone? still looking for answers. appreciate any more ideas or similar problems that have been experienced
Old Jul 19, 2009 | 12:11 PM
SiRkid's Avatar
hondata issue? have you contacted them?
could be some silly check box or something
DarikDisease
Aug 26, 2008 01:29 PM
teamitr
Mar 2, 2008 08:30 PM
CeeJayy
Jul 27, 2007 01:36 PM
DragonLord
Nov 23, 2006 06:37 AM
kraig8
Dec 18, 2005 02:10 PM
