Loose spring?
Old Jul 16, 2009 | 12:47 PM
zach1288's Avatar
Default Loose spring?
I recently installed new KYB GR-2's on my car. I noticed that the spring(eibach sportline) is loose between the top and bottom perch? Is this normal? This is only true when the car is completely jacked up.
Old Jul 16, 2009 | 12:54 PM
90_EX_Civic's Avatar
Default Re: Loose spring?
yes, it's normal. that is if the sportline springs them selves are shorter then your oem spring. which it should be.
Old Jul 16, 2009 | 01:06 PM
zach1288's Avatar
I had my car at an alignment shop today and they said they could not align my car becuase of the loose spring.
Old Jul 16, 2009 | 01:49 PM
96DelSol's Avatar
It's normal I have the same springs in front.
Old Jul 16, 2009 | 01:58 PM
TunerN00b's Avatar
Then you should find an alignment shop with a competent technician.
In some states, having a spring loose at full droop is grounds to fail a safety inspection. People in those locations need to use tender springs to take up the extra space.
However, many of us have all 4 corners do this when the car is jacked up, without ever having an issue with it. 3 years now, never a problem for me, and I lift an inside rear tire cornering. The swaybar keeps the spring in place when a wheel leaves the pavement.
Old Jul 16, 2009 | 02:36 PM
waaBAAH's Avatar
that looseness gets filled when you lower the car.
tech should have said.. "no alignment due to vehicle not being "stock" height.
Old Jul 16, 2009 | 02:52 PM
zach1288's Avatar
So it is perfectly align-able?
Old Jul 16, 2009 | 03:08 PM
yes
Old Jul 16, 2009 | 03:27 PM
esean93's Avatar
Yeah some alignment shops don't align lowered cars.
Bjorn20
Oct 16, 2005 09:19 AM
4G63
30
Aug 13, 2004 09:46 PM
UdontknowME
Jun 29, 2003 02:48 PM
