B18B1 build
Old Jul 16, 2009 | 09:01 AM
fireblaze2k1's Avatar
Default B18B1 build
I'm building my B18A/B1 right now. I've put together most of the bottom end and have started to get head put together. Before I put the time belt on, how easy should the crank turn after it's all together? I have no flywheel on it at this time, just crank, rods, pistons, rings.
I'm using a lot of force to turn it, and it sticks. Anyone have any suggestions?
Oh yeah all the bearings are new and I greased them all, and I have ARP rod bolts.
Old Jul 16, 2009 | 09:09 AM
1ls/vtec's Avatar
Default Re: B18B1 build
if its hard to turn then that means that ur compression is good. what are u trying to do to the motor?
Old Jul 16, 2009 | 09:29 AM
lol I totally forgot I hadn't taken off the old sparkplugs yet.
The goal is ls boost. I have a B1 head I'm gonna have work done on, but I wanna put the new engine in now b/c I'm impatient and have the head changed after it gets pieced together. Then I'mma piece together my turbo kit. Looking to get 250-300 WHP
Old Jul 16, 2009 | 10:09 AM
wrenchez81's Avatar
did you make sure you put the con rod. caps on the right way??
Old Jul 16, 2009 | 10:56 AM
iamthefollower's Avatar
good luck on the build and do a build thread when you get the chance, I would like to see it...
Old Jul 16, 2009 | 06:29 PM
1ls/vtec's Avatar
hells yeah man, sounds good. I would love to boost my lsvtec, but its kinda hard to with 10:8:1 comp, and stock p28.lol, but yeah good luck with the build. remember take ur time and do it right the first time.
Bense
14
Jun 21, 2006 11:53 AM
untitled
Jan 15, 2004 01:57 AM
ls_vtec_b18a1
Oct 21, 2002 07:35 AM
