air fuel gauge.
Old Jul 16, 2009 | 08:36 AM
chrisfromsrq's Avatar
Default air fuel gauge.
so i want to put a air fuel ratio gauge in my car but heres the problem. i dont no which one to get and i looked down the backside on the header by the firewall and the sensor that is below the throttle body had cut wires. which is why i believe my check engine light is on. also i dont have a cat on the car and the engine is a b20. anyone got any input of how i can hook up a airfuel gauge and which one to get? and is it worth it? i really just want it to get rid of the boost gauge in the pod because the car used to have a boosted gsr. i cant take the pod off because there is a big hole behind the pod. any sugestions and help id appreciate it.btw i dont no how to hook up a airfuel gauge but i was just guessing that was the o2 sensor that i was looking at.
Old Jul 16, 2009 | 08:38 AM
90Rexx's Avatar
Default Re: air fuel gauge.
get a wideband guage.... the narrowband rainbow guages are dumb....
Old Jul 16, 2009 | 08:45 AM
vtechjunkie's Avatar
PLX makes a nice wideband. Narrow bands are dumb like "90Rex" said. They come with directions to help with install. As far as just trying to eliminate the boost gauge; why not just replace the panel? Is the motor built? In other words do you need a wideband o2? Or any gauges for that matter? But the fact of the matter is: it's your car. So that being said, GL.
Old Jul 16, 2009 | 08:58 AM
TravisCadello's Avatar
the wideband ones are expensive. i think.
Old Jul 16, 2009 | 10:36 AM
this is everything ive done to the engine. internals are stock.
engine/Drivetrain Modifications:
jdm b20b with around 69k
usdm GSR tranny
ITR shift Linkage
ACT stage 3 clutch 6 puck sprung
Fuel Regulator
Fuel pressure Gauge
Golden Eagle PRO SERIES fuel rail
Old Jul 16, 2009 | 11:00 AM
90Rexx's Avatar
you can get an AEM EUGO setup for like 280 shipped off ebay....
Old Jul 22, 2009 | 11:32 AM
ok so when i go to hook this up does the o2 sensor have to be hooked up to the computer? or can i hook the gauge up to the o2 sensor n be fine? the o2 sensor is in the header but all the wires are cut. nothing hooked up.
Old Jul 22, 2009 | 11:46 AM
90Rexx's Avatar
with a WIDEBAND guage, the sensor just goes directly to the guage, no wiring goes to the ecu. just power and ground for the guage, then the sensor plugs right into the back of the guage.
Old Jul 22, 2009 | 11:50 AM
ok so when i run the wires for the gauge i can just run them right to the o2 sensor and the power to the fuse box and ground to frame correct? im going to pick up my gauge today so i dont no what wires are on it. all i know is there is a few different wires cut from the o2. i didnt count how many i just know they are all cut with about 2 or 3 inches of wire coming off of it.
Old Jul 22, 2009 | 12:10 PM
90Rexx's Avatar
wideband or narrowband?
Old Jul 22, 2009 | 12:18 PM
wideband.
Old Jul 22, 2009 | 12:30 PM
thumper64's Avatar
Narrow bands only accurately read a very narrow range. A wide band is far more precise. PLX makes a fairly inexpensive one and you can find it on eBay. Thats what I went with since it was cheaper than the others I was considering.
k_bster24
15
Apr 11, 2004 06:39 PM
b16ahybrid
Apr 17, 2003 09:19 AM
phazeshifter
Nov 5, 2002 06:09 AM
phazeshifter
Nov 4, 2002 08:50 AM
phazeshifter
Nov 4, 2002 07:25 AM
