getting a little bit more practice in, some collector pics
Old Jul 15, 2009 | 08:40 PM
russianvr4's Avatar
OG Fabricator
Default getting a little bit more practice in, some collector pics
Finally getting my shop close to set up, started working on some fab projects. here's a 3-1 collector for a single turbo setup. cuts arent PERFECT yet but the next one should be gapless. getting a little bit more consistent with my welds, still need to work a bit on color.
looks like im getting ~70% penetration.
heres some pics
Old Jul 15, 2009 | 08:41 PM
russianvr4's Avatar
OG Fabricator
Default Re: getting a little bit more practice in, some collector pics
sorry for quality, my regular camera seems to have taken a **** on me so im using my iphone.
Old Jul 15, 2009 | 09:10 PM
SoTexDC2's Avatar
What platform are you working with that has a three cylinder?
Old Jul 15, 2009 | 10:18 PM
russianvr4's Avatar
OG Fabricator
It's a v6 :p
Old Jul 15, 2009 | 10:38 PM
SoTexDC2's Avatar
Originally Posted by russianvr4
It's a v6 :p
dumbest question I've ever asked.
What is it for?
Old Jul 15, 2009 | 11:09 PM
d16sandrail's Avatar
^^^I've always heard there is no such thing as a stupid question :-) ^^^ haha! thats great.
Old Jul 15, 2009 | 11:10 PM
honduh_head's Avatar
its for a geo guys, i mean CMON!
:p
Old Jul 16, 2009 | 09:17 AM
m R g S r's Avatar
i would weld the inside of the collector as well, doesnt look like you got too much penetration there.
if you are having trouble penetrating the metal all the way, either turn up the amps or move slower, or both. just make sure that you have enough postflow (time, not necessarily more gas flow) to make sure the weld puddle completely cools while being shielded by the argon. little color or a grey weld will not necessarily mean it's too hot, it could mean not enough gas coverage.
on my sync 200 the auto postflow never seems to be enough to give the weld a lot of color. i always have to tap the pedal to keep the postflow going...i usually do that when the timer on the machine is around 2 seconds or so.
Old Jul 16, 2009 | 09:48 AM
I wanna see it welded on a flange or vband...
Old Jul 16, 2009 | 11:50 AM
russianvr4's Avatar
OG Fabricator
thanks for the tips!
i'll weld them to vbands pretty soon.
Old Jul 16, 2009 | 05:17 PM
russianvr4's Avatar
OG Fabricator
heres a few more pics of the header im building
Old Jul 16, 2009 | 06:40 PM
dart2.2's Avatar
Id put a little more of a bevel on your cuts.
Old Jul 16, 2009 | 07:19 PM
gtconcepts's Avatar
What up bro! , Is Gil what turbos u will use? tdo5 or t3?
Old Jul 16, 2009 | 07:44 PM
russianvr4's Avatar
OG Fabricator
sup gil!
its going to be a single turbo setup. i hate twins
Old Jul 16, 2009 | 07:47 PM
russianvr4's Avatar
OG Fabricator
a few more pics
Old Jul 16, 2009 | 08:48 PM
gtconcepts's Avatar
Looking good man , as an advise u need to give the #5 piston runner more length just to balance the air flow in between runners and u will run in the same issue in the back with piston runner #6 , u would have benefit more with a longer collector u got plenty of space.
good luck
Gil
RadRonny
May 24, 2006 02:10 PM
madhatter07
Welding / Fabrication
26
May 3, 2005 08:44 AM
sohcvtec97
Apr 14, 2005 06:00 AM
Heinz57
77
Mar 5, 2005 12:08 PM
YumVTEC
Mar 13, 2004 11:22 PM
