setting up ECU for PWM, ? about D14
Old Jul 15, 2009 | 03:15 PM
xander1100's Avatar
Default setting up ECU for PWM, ? about D14
the peice that im supposed to weld into D14 has red tape on one end and white on the other. the D 14 socket has a white arrow going from the right to the left socket. which wire goes where?
Old Jul 15, 2009 | 05:26 PM
Blown90hatcH's Avatar
Default Re: setting up ECU for PWM, ? about D14
What are you doing that requires you to weld in something at D14?
Old Jul 15, 2009 | 06:30 PM
mtber's Avatar
The white stripe on the diode faces the plug side of the ecu.
The two resistors can be installed facing either way...
The transistor at q29 faces you with the ecu plugs to the left....
This should be pictured in the diagram provided with what ever pwm install kit your using.
Old Jul 15, 2009 | 06:39 PM
xander1100's Avatar
cool thanks.
Old Jul 15, 2009 | 07:09 PM
You ruined my "weld" joke hater...lol
Old Jul 15, 2009 | 08:16 PM
xander1100's Avatar
sorry meant solder...been reading a book on welding all day.
lsturboguy
Jun 3, 2007 02:27 PM
rice crispies
Jul 5, 2005 08:07 AM
dropd4door
Oct 5, 2004 06:20 PM
hondacrx90
Apr 3, 2004 08:20 PM
nutsack
Oct 28, 2003 10:38 PM
