brake booster dilemma.
Old Jul 15, 2009 | 01:26 PM
maxwellmercer's Avatar
Default brake booster dilemma.
i just got a steal on an 89 crx si but with one little catch. it has "manual" brakes.
it stops just fine just takes a lot of leg effort, he told me it was plugged for some reason so when i got it home, i check it out and the line from the booster to the intake manifold was non existant and capped off on the intake manifold.
i replace the line as it should be, started it and touched the brakes. it felt normal but it caused a HUGE vacuum leak.
any suggestions?
thanks!
Old Jul 15, 2009 | 01:32 PM
D16SiHatch's Avatar
Default Re: brake booster dilemma.
most likely there is a tear in the boosters diaphragm. replace the booster and you should be good to go.
Old Jul 15, 2009 | 10:12 PM
i figured as much. thank you sir!
99teggsr
Jun 9, 2013 06:39 PM
kazaa187
May 26, 2013 01:51 PM
Eighty-Nyne
12
Apr 28, 2009 07:59 PM
jikespingleton
Jan 2, 2007 01:31 AM
egcoupeautox
Oct 16, 2005 06:23 PM
